R55 NCS Expert can't read from 4 modules
Old Apr 16, 2022 | 12:41 PM
Clockwork's Avatar
Clockwork
Hi all, I wanted to see if anyone has any advice about best approach for a small issue I'm having.
I am running NCS Expert to read all modules from car and will modify some. I am having issues retrieving the current coding (.TRC files) from 4 modules (RLS, SZL, SPEG & FRM).
I read on a few coding sites with NCS Expert, that it you can reset modules back to factory (there is a document from bmwcoging.com that showa how to do so properly adn NOT using the blank .MAN file, as that is not the proper way)
I can try that first, then see what custom coding I have lost, then retrieve the codes from NCS Expert (fingers crossed I do, Or I lost the custom coding in that module, for no reason) and then adjust and reload...
lets hope this works.
Old Apr 19, 2022 | 02:31 PM
mrbean's Avatar
mrbean
Are there other modules in the car that you can read/write to or are those 4 the only ones you've attempted to recode?
Can you connect to those modules with other standard tools software, like ISTA?
When coding with a blank .man file you need to make sure your profile settings are correct. There are lots of tutorials online on how to do this.
Old Apr 19, 2022 | 02:40 PM
Clockwork's Avatar
Clockwork
Hi Mr. Bean,
yeah I manged to pull/modify the code/upload code back to 4 other modules.
I am still researching a lot adn it seems something to do with version of daten files and the edibas.bin.ini file... I'm gonna read more, but I just find it weird that SOME modules can be read, in NCS Expert and re-coded adn some can't.
as for using Rheingold or INPA, those softwares can read/access ALL modules, thankfully. So that makes me lean towards daten files...
the can us running fine, but I just wanted to customise, and am surprised I'[mm getting these errors.
I've never seen these errors on my e53 or e31 (very limited code changing options on e31)
Old Apr 19, 2022 | 10:58 PM
adriancl's Avatar
adriancl
Just for info, in case of damaged FRM due to battery disconnect, can restaure easy to factory , no need NCS Expert,loook at video.
Old Apr 26, 2022 | 10:29 AM
Clockwork's Avatar
Clockwork
thanks very much for the video, but I dont have that software to do that modification.
NintenTom
Electrical
54
Jan 30, 2019 07:50 AM
OwenRW
Electrical
14
Aug 20, 2018 06:55 AM
schrottpresse76
May 8, 2015 03:50 PM
TiggerGTO
Electrical
24
Apr 19, 2012 03:27 PM
