R56 Coding Attributes 25W Xenon Headlights
Old Apr 16, 2022 | 12:22 AM
Katchmarek's Avatar
Katchmarek
What Coding Attributes do i need, to Coding the 25 W Xenon Headlights?
First of all i would das $522 in vo? But what Else in the frm or nfrm? The Auto leveling? Auto lwr? High and Cold Check?
Old Apr 16, 2022 | 07:49 AM
Gubi's Avatar
Gubi
Here's the procedure using Bimmergeeks:
https://www.northamericanmotoring.co...ml#post4588923
Old Apr 16, 2022 | 08:26 AM
Schimanski's Avatar
Schimanski
But i only have ncs expert
Old Apr 17, 2022 | 08:28 AM
Gubi's Avatar
Gubi
Bimmergeeks is just a package for NCS Expert. If you go through the instructions on that page you can likely find what parameters you need to code.
Old May 3, 2022 | 01:15 PM
Jmaxxz's Avatar
Jmaxxz
Just did retrofit of 25W xenon's on MCS 2012 followed @ragingMINI 's post #112 in https://www.northamericanmotoring.co...ml#post3916532
After adding $522 to the FA I did a SG_Codieren to the CAS and FRM to code the new vehicle order information and default the modules. Just doing a FA_Write is not enough. Initially I tried just doing an FA_Write and they headlights would strobe once the car was turned on. I then removed $522 doing an FA_Write to the CAS and FRM, to get them back into the previous state. Then I added $522 back to the FA and did a SG_Codieren to both modules. After this I proceeded to disable auto-leveling and charging PWM_FL_BEI_BIXENON to wert_01
OnsideHAZOR
25
Jul 20, 2024 08:30 AM
cw40342
Oct 27, 2015 12:30 PM
neonsteve
Electrical
Jan 20, 2015 02:39 PM
jthorst75
Dec 17, 2012 06:30 AM
