R55 with the N14 Engine. No start. HFPF or LPFP?
Old Mar 23, 2022 | 10:18 AM
cyoxms's Avatar
cyoxms
Hey gang, trying to figure out which direction to go with this issue, and hoping someone here can point me right.
I've got a 2010 Clubman S with just over 100k miles. Repairs that have already been done: Timing Chain, New Transmission, Clutch, Flywheel, Pressure Plate, Footwell Module. Known but unaddressed issues: water leak shorted out the keyless entry and radio controls last fall.
Couple of weeks ago I went a few days without driving the car (during some cold weather) and when I went to use it, it wouldn't start. Had not had any mechanical issues in quite a while. Battery was pretty old, so I swapped that out, but no dice.
Car tries to crank, and it seems like it is going to turn over, but never is able to. Starter seems to be engaging, the tach needle jumps a bit when I try to start the car.
At this point I'm thinking is a fuel pump issue. I'm unable to hear anything when I put my ear up to the fuel filler when trying to start the car, but I honestly don't have a trained ear to know if the LPFP is engaging.
I guess my main question is whether this sounds like a HPFP or a LPFP issue, or if there's something that I may not be considering.
Any help would be very greatly appreciated!
EDIT: Only code I got on the OBD2 was P15E8.
Old Mar 23, 2022 | 08:00 PM
HerrGruyere's Avatar
HerrGruyere
When you mean tries to start, does the motor actually turn over a few revolutions with the starter engaged? If so, then I’d suspect a fuel pump. If the motor is not turning at all, then I’d look to a short or something. I had a similar problem and a battery seems to have resolved it, but I have a feeling it might return.
Some other drivers reported the engine or coolant temp shorting out allowing the fan to run and drain the battery. This also signaled a leaking thermostat housing.
Old Mar 24, 2022 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Here is a thread with same code as you:
https://www.northamericanmotoring.co...ont-start.html
JTolliver
May 3, 2022 07:57 AM
adVANtec
Mar 22, 2017 02:50 AM
rasmith6
Dec 14, 2013 06:30 PM
LobsterMINI
Apr 18, 2010 06:19 PM
rollermonkey
Feb 16, 2006 07:37 AM
