R59 Battery Replacement for 2014 Roadster S (R59)
Old Mar 4, 2022 | 12:47 PM
MavenBit's Avatar
MavenBit
Cool Battery Replacement for 2014 Roadster S (R59)
Hello everyone!
I need to replace the BATTERY on my 2014 Mini Cooper Roadster S (R59) and am a bit confused. On all sites I've been to the battery tools give me the option of "H5" and "H6" group sizes as options but how can there be 2 group sizes for my mini?! Which one should I go with? If someone could send me a link with the proper information I would appreciate it. Thank you in advance for your help, it's much appreciated!
Seb
Old Mar 4, 2022 | 01:06 PM
Capt_bj's Avatar
Capt_bj
https://drivermoola.com/h5-vs-h6-battery/
The biggest difference between h5 and h6 batteries is their weight. H5 batteries are lightweight, but h6 batteries are comparatively heavier. This is why h5 batteries are mainly used for racing and performance-based use. H6 batteries are heavier and give you the extra capacity, and are better if you are driving in colder areas.
this chart also shows that the physical dimensions of the H5 are a bit smaller than the H6 so if there is sufficient space for the 6, the 5 will fit ....
p.s. don't forget you should 'register' the new battery. Failure to do so can significantly lower the life span of the new battery due to the IBS (intelligent battery system) which 'adjusts' the charging as the battery ages. You want to reset the system to 'new battery' and full charging.
Old Mar 4, 2022 | 03:02 PM
MavenBit's Avatar
MavenBit
Hello Capt_bj,
Thank you so much for the help, I appreciate it!!
Old Apr 19, 2022 | 01:57 AM
hailey grey's Avatar
hailey grey
thank u for the infos
192.168.100.1 192.168.1.1
Old Apr 22, 2022 | 06:12 AM
TG.'s Avatar
TG.
Recently bought this one for ours:
https://www.batteriesplus.com/batter...SAAEgLX8vD_BwE
Delpel
May 13, 2021 09:54 AM
Grey Thunder
R59 :: Roadster Talk (2012+)
May 3, 2021 01:57 PM
smurfette26
24
Aug 16, 2019 03:12 PM
ervicta
R58 :: Coupé Talk (2012+)
15
Jun 12, 2018 03:27 AM
cartman
Jul 24, 2017 09:12 AM
