R56 Mini One 2008 VVT Issues
Old Jan 25, 2022 | 02:10 PM
teo's Avatar
teo
Hi everyone,
I have had some issues with the valvetronic on a recently bought Mini One. The first problems appearing were 2868 Valvetronic motor, sluggish movement and 285E Valvetronic adjustment range. I have managed to sort out the sluggish movement problem by replacing the motor as it wasn't smooth to turn it with a hex key.
I can't sort the adjustment range and I've tried to relearn the adjustments but ISTA fails to do so, I can hear the motor turning for 2-3 seconds and then it stops. Reading the eccentric shaft values I can see that the actual value is stuck at 180deg and it's not changing even by turning it manually. The eccentric shaft set value is changing but I guess that's what the ECU tells the motor to turn to.
I don't have any eccentric shaft sensor codes thrown but obviously the fact that it's stuck at 180deg seems like a problem. Do you think I should try and replace the sensor?
Cheers!
justjeff
46
Nov 9, 2020 04:15 PM
CooperSPT
Mar 1, 2020 02:05 PM
bartk_k
Dec 7, 2019 04:32 AM
MarioKart
Feb 28, 2008 11:31 PM
ChrisW
132
Mar 29, 2007 10:54 AM
