Electrical Led Side scuttle hyperflash
Old Jan 21, 2022 | 09:25 PM
devenaggarwal's Avatar
devenaggarwal
I recently bought some sequential side turn signals for my LCI R56 Cooper S. The listing advertised the signals to be CANBUS/no hyperflash. These signals look awesome when the car is off but as soon as I turn the engine on the signals begin to hyper flash. I really don't want to add a resistor because I am uncomfortable with splicing into my harness. I had checked bimmercode to see if there was an option to set the side turn signal bulbs to LED which I did but it did not solve my problem. Is there something through bimmmercode that I may be missing? Another option that I would be open to are different sequential options around the $20-30 range that you know is a direct plug and play?
Old Jan 21, 2022 | 11:05 PM
MVPeters's Avatar
MVPeters
Probably the simplest is to turn the hot & cold bulb checks off altogether.
If you want to keep the checks, you'll need to find better turn signals.
Old Oct 13, 2024 | 06:06 AM
DogfaceSGM's Avatar
DogfaceSGM
Curious if you got these working? I bought a set on Ebay that look great, work fine when powered on only, start the engine it flashes 5 times then quits. I have tried multiple things with both BimmerCode and NCS Expert.
https://www.ebay.com/itm/126408758236
devenaggarwal
Jan 15, 2022 12:52 PM
pfdaxe
Jun 19, 2018 04:36 PM
RicWRX
Dec 21, 2013 08:42 PM
matma92ser
Feb 1, 2011 05:02 PM
cooleric2000
Jul 30, 2010 05:07 PM
