2C58/2D60 every start now
Old Dec 27, 2021 | 10:18 PM
veelangs's Avatar
veelangs
Very annoying, car basically blows this error every start and then I use bimmerlink and it clears after a few clears and a key out restart and we're good. Driving me mad obviously, thinking it might be a vanos solenoid? The car runs absolutely fine regardless, just loves this stupid limp mode error.
I think the colder weather is bringing it up more, but overall just wishing it'd go away!
Old Dec 28, 2021 | 12:24 AM
robbo mcs's Avatar
robbo mcs
They are 2x different codes
2C58 is a boost pressure plausability error. This is a collective fault, related to other codes, no recommended actions
2D60 is a Vanos / exhaust valve / control valve fault. Potential problem source(s):- Contaminated oil passage at VANOS solenoid valve- Oil pressure too low- Defect in wiring harness to VANOS solenoid valve- VANOS solenoid valve seized. Recommended actions : Check oil level, change engine oil and filter as indicated- If faults related to the camshaft position sensor have been logged, repair these first- Check wiring harness between VANOS solenoid valve and DME- Perform system test - Check camshaft and VANOS unit for freedom of movement and mechanical damage- Clean VANOS solenoid valve, replace as required-. Also mentions that this can lead to code 2C58, as boost pressure is deactivated to protect engine
Old Dec 28, 2021 | 03:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Based on the above, I would replace the exhaust vanos solenoid. It’s failure will affect cold start.
Old Dec 28, 2021 | 06:56 AM
veelangs's Avatar
veelangs
Thanks for the heads up, is the exhaust one accessible without removing the turbo piping? The guide I see online is for an n16 engine
Old Dec 28, 2021 | 07:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I hadn't removed the piping when I swapped mine out. It's on the front of the engine, next to the dipstick. Disconnect the electrical connector, remove the retaining screw, and pull it out. Install in the reverse.
Old Dec 28, 2021 | 08:58 AM
veelangs's Avatar
veelangs
perfect, i'll order a new one right now
thanks bud
obgmugen
Dec 10, 2021 05:14 AM
MandB
E-Mini (2020+)
May 25, 2021 06:33 PM
sal1k
Jul 25, 2014 07:17 PM
starionturbo
Sep 18, 2011 12:16 PM
BuckeyeMCS
Apr 29, 2004 03:32 PM
