How to access pistons
Old Dec 17, 2021 | 07:25 AM
Briscoec's Avatar
Briscoec
I have had an 07 mini justa (N12) for a little over a year, bought for my granddaughter. I thought she was 16 in '21, naa, only 15. So I've garage kept her car and gone through it. Many electrical bugs cleared up (Thank you Minitobe). It was burning a little oil and of course at 107K miles, needed some work on the valves seats. The engine is removed, not a bad deal.
Here is my question:
I've pulled off the cylinder head and several of the valves are really tired. I plan on buying a rebuilt cylinder head. Pretty good deal
The short block, to my surprise is in excellent condition. Top of pistons look great, a little carbon deposit, but walls are smooth. I will certainly replace the rings at this point, However, the Bentley Book doesn't show anything on accessing the main engine block.
? Do I remove the lower unit above (or underneath) the oil pump?
? Better yet, is there a link available to a exploded view, breakdown?
Thanks for your help. This site has allowed me to correct a mistake I made when I purchased this car. Cute, is never a good reason to buy a car. I have tried looking up this info from past threads. However, my queries always show 50 things I'm not searching for. I'm sure there is a way, but I am sucking air on search information.
Regards,
Briscoe
Old Dec 17, 2021 | 11:54 AM
cooper48's Avatar
cooper48
I'm not sure I understand your question. This illustration may help (or information contained at realoem.com). You shouldn't have to split the block as the piston rods/bolts are accessible from below between the crank journals.
Old Dec 19, 2021 | 05:52 AM
Briscoec's Avatar
Briscoec
Yes sir, had no pics of where to access pistons.
Sort of thought it was there, thanks
Old Dec 19, 2021 | 02:54 PM
930 Engineering's Avatar
930 Engineering
You'll find several part numbers and alternative parts in some cases you might need here:
https://www.leebmann24.de/bmw-ersatz...31&og=01&hg=11
It's German but quite easy to understand from the pictures. Just google the part numbers afterwards.
For example:
piston rings OE BMW:
11257566479
piston rings MAHLE:
081 RS 00104 0N0
Old Dec 19, 2021 | 06:22 PM
Briscoec's Avatar
Briscoec
Excellent
I was steered toward Mahle, thanks for the confirmation. BMW quit making parts and then rebuilders dropped the N12. I would dread trying to swap out engine models to an N14. Wow.
Old Jun 7, 2022 | 10:53 AM
930 Engineering
N12 pistons and rings are still easily available both from BMW and Mahle via every European
BMW dealership and hundreds of independent vendors dealing with Mahle parts respectively:
https://www.leebmann24.de/bmw-ersatz...=11&bt=11_3921
Hardly a issue.
keineth Ewell
Jul 17, 2022 06:54 AM
BRGNigel03
Sep 1, 2019 11:30 AM
speedmob
Jun 7, 2018 01:21 PM
ICallMyCarKate
Jul 11, 2016 07:24 AM
Fordgt4
Oct 10, 2015 10:42 AM
