Mini/MINI BUILDS Showcase your Build Talents.
The autoX Mini has gotten crazy
Old Nov 16, 2021 | 06:04 PM
jetsr6's Avatar
jetsr6
The autoX Mini has gotten crazy (now 377whp)
Dyno’ed 333whp low 20psi boost… hit 28psi at the 1/8 mile with the scramble paddle shifters.
Cortex boost by gear and port fuel injection. RpmPowered open boost map. Garrett gtx2860r gen 2. Water to air intercooler. Wotbox. And much more.
Mod list
2007 Mini Cooper S
-Custom K&N cold air intake routed to fog light hole
-billet RPM Powered manifold with port injection
-Cortex EBC boost by gear
-E22 ethanol mixture
-Turbosmart iwg75 dual port
-Garrett GTX2860r gen2 ATP kit
-Kompack dual port blow off valve
-3 inch downpipe
-Custom straight aluminum mid pipe
-3” Magnaflow muffler straight through
-W2A intercooler 2.5IC pipe setup
-2019-BC racing coilovers with Swift Springs, revalved by RedShift to give better dampening. Stiffer compression, lighter rebound.
-25mm hollow rear sway bar set to stiffest setting
-Hawk HP Plus pads rear
-2019-Wilwood Big Break Kit (front) 4 pot (4 stainless steel pistons to compress brake pads)
-Hoosier A7 tires 275/35r17 front 225/45r17 rear
-Powerflex bushings throughout
-3J driveline LSD, clutch type
-OS Gliken str flywheel and clutch
-GoNMF oil additive
New engine setup
N14
K1 rods
CP 10.5 77.5 pistons
ARP everything
Cyro timing chain kit
ACL race bearings
Supertech Ti retainers
Beehive valve springs
Cat cams #1302603
G-plus oil cooler with thermostat
Wotbox
RPM Powered Stage custom open BOOST map
Amsoil dominator 10w40 mixed
Amsoil 80w90 gear oil for trans
A lot of weight reduction- 2300lbs
-2 .8 degree of camber in the front, -2.6 degree in the back 1/8” toe out front anod rear
Accomplishments
2020 2021 overall champion local ODR SCCA
2020 Winter SCCA Dixie Solo champ tour overall winner
2021 wife won SMFL solo nationals
2021 Mini won 5 out of 6 SCCA Solo Champ tours in SMF
Old Nov 17, 2021 | 03:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
That torque curve!
Old Nov 17, 2021 | 04:58 AM
jetsr6's Avatar
jetsr6
Nice thing with the cortex ebc is I can change how the boost comes in so. So this works great for traction in 2nd gear. Now need bigger injectors for the rest of the gears with higher boost🤦‍♂️😂
Old Nov 18, 2021 | 12:55 PM
oldbrokenwind's Avatar
oldbrokenwind
How sweet it is!
Hope you have sleeves or a CSS --- that kind of power is pretty close to the max for an N14 / N18 that has un-supported cylinder walls.
I'm still running OEM injectors, but added 4-port WMI (80 - 20 mix) to supplement fuel requirements. Got over 500WHP with 29PSI boost. Don't expect much more than 400WHP out of a GTX2860R Gen2 --- boost curve sags 6 - 7PSI starting around 4K RPM.
Post a link to your build thread?
Old Nov 18, 2021 | 01:18 PM
jetsr6's Avatar
jetsr6
No sleeves or cylinder support. I actually never planned to make over 300 WHP. But I found the ATP kit on eBay for 900 bucks and I couldn’t pass it up lol. But I’m not worried about the cylinder walls. Most the time I’m only in second gear anyway. I don’t think I ever did a build page maybe a few times I’ve listed all the mods but it’s about it. 500whp sounds like a real handful lol
And I’m not running water meth injection because the rules don’t allow it. So that’s why I had to go with fuel port injection. Plus I’m running E22 which requires more fuel.
Old Nov 18, 2021 | 01:41 PM
jetsr6's Avatar
jetsr6
Latest addition is the new tach dash. With RaceCapture track mk2
Attached Thumbnails The autoX Mini has gotten crazy-7fdacde4-53e5-426a-9dd6-1a3805268d29.png
Old Nov 18, 2021 | 02:00 PM
oldbrokenwind
Added info subs for a build thread --- thanx.
Here's a pic of my 10.5:1 CR piston / cylinder wall after a 30PSI boost run at around 330WHP. My first big breakdown. It was a CP piston too. Engine kept running, just really rough, and burned up the intake cam and a couple head journals. Learned a lot after that experience. If you keep it at 22PSI max, you might be OK.
Best of luck, should be lotsa fun ---
Old Nov 18, 2021 | 02:19 PM
jetsr6's Avatar
jetsr6
I shouldn’t have any problems with the way I have my boost coming in. Guess I’ll find out the next time I hit up the dragstrip🤞 Maybe this winter I’ll send my extra block to get the ccs done.🤔
Old Nov 18, 2021 | 04:29 PM
oldbrokenwind
Dragstrip is where I broke mine. Time was terrible --- results of big, slow-ramp turbo and light flywheel --- loss of low RPM inertia, therefore slow launch.
These guys are the best --- https://www.cylindersupportsystem.co...R26x53-qiqMq0Q you won't regret it.
"1st Run" was the best time, it broke on the 2nd.
File Type: pdf
Old Nov 19, 2021 | 06:13 AM
Minibeagle's Avatar
Minibeagle
Living the dream! I would love to be a passenger in that thing when you're giving it the beans at autocross!
Making the performance and handling MINI family proud. Keep up the great work!
Old Nov 19, 2021 | 06:15 PM
jetsr6's Avatar
jetsr6
Thanks! Its been a blast!!
Old Nov 19, 2021 | 06:17 PM
jetsr6's Avatar
jetsr6
What turbo were you using when this happened?
Old Nov 20, 2021 | 01:00 PM
oldbrokenwind
Originally Posted by jetsr6
what turbo were you using when this happened?
gtx2860r
Old Dec 10, 2021 | 08:41 AM
jetsr6's Avatar
jetsr6
We are now 377whp at 25psi after tuning in bigger port injectors. Was running out of port injectors before above 24psi so now it’s safe🤔😬
Old Dec 10, 2021 | 11:37 AM
oldbrokenwind
I've yet to learn about different fuel systems, so I don't fully understand your setup. You're running E22 in the gas tank? Then it's fed thru the OEM lines / pumps / and injectors PLUS the RPM manifold's four ports? Or, did you bypass / move the OEM injectors and go from HPFP to RPM's manifold, and plug the head ports? OR ---?
However you've got it set up, your results are really NICE --- congrats! Gotta ask --- my lite flywheel and slow-boosting turbo seem to cause slow launches --- can't spin tires. Are you experiencing similar results? On the plus side, high RPM acceleration is awesome --- truly addictive!
Earlier I mentioned a "boost sag" out of my previous GTX2860R. Here's a chart from one of my earlier dyno runs showing only the AFR and boost. Most of the "damage" shows up in the torque curve. HP didn't show a drop (torque and HP charts not attached). Looking at your torque curve, there doesn't seem to be any serious boost "sagging", and if you keep it below 25PSI, you might never see any. One more reason to keep the EBC set below 25PSI.
Old Dec 10, 2021 | 01:08 PM
jetsr6's Avatar
jetsr6
Yes I’m running e22-23 in the tank. Basically 4 gallons of 93 mixed with 1 gallon of e85
Upgraded intank fuel pump to a 450 Walbro fuel pump using oem fuel line. And then fuel line goes from one side of the fuel rail on the manifold out the other side into the high-pressure fuel pump. So the port injectors always see the low pressure side of the fuel system. So I am running eight injectors. The DME still controls the 4 direct injectors. I control the port injectors with the boost Cortex EBC boost by gear controller. So the port injectors only spray when in boost.
I can spin the tires pretty easily in first gear launching at 3800 RPMs using a wotbox. I have a light flywheel set up as well. But I’m also using higher compression pistons so I’m not losing as much of the bottom end rpm grunt. Everything over 4Krpms is very responsive.
EBC I ramp in the boost. I tune in the port injectors and I really don’t want a big boost spike down low because it makes it undrivable and safer 😂 but here is my boost duty cycle set up.
See here.
Green is rpm, blue is duty cycle, red is actual boost. This is the log from the dyno graph.
axleR56
Jan 30, 2012 07:56 AM
scolburn79
Sep 4, 2007 04:43 PM
2005MCS/KK
Sep 12, 2006 07:22 PM
willy69
Feb 9, 2006 07:19 AM
ZAMIRZ
Dec 10, 2003 03:14 PM
