Wiring under seat issue
Old Nov 16, 2021 | 05:12 PM
uluz2a6's Avatar
uluz2a6
2012 Mini Cooper 1.6
140K
Automatic
Purchased for my daughter in non-running (poorly running) condition from a bent valve(s). Removed and replaced cylinder head, timing chain, etc. Runs great but now has an ABS light and engine light. ABS code refers to a passenger seat occupancy issue. Engine light refers to a DSC sensor that also (as I can tell) located under passenger seat. Removed the seat and found harness severed and "hacked" partially back in place. Also appears seat doesn't match this vehicle.
I replaced both the driver and passenger seats with proper units that have unmolested wiring harnesses. I also cut a replacement harness for the vehicle side of the wiring. I see all the color wires are present on both my vehicle as well as the donor harness.
My concern is with the multiple brown wires (I assume are grounds) and I don't want to mix and match if that will apply ground circuits to wrong modules. Especially since some are clearly ABS.
Am I over thinking this or does it matter?
Old Nov 17, 2021 | 07:43 AM
mrbean's Avatar
mrbean
A ground connection is a ground connection.
What is important is making sure the gauge of the wires match. Don't hook up a heavy gauge wire from the seat side to a light gauge wire on the vehicle side.
E34M5
Sep 23, 2020 08:40 AM
RCWD21
Aug 17, 2020 10:45 PM
AbusedR53
Nov 13, 2018 12:36 PM
MiniPug
May 14, 2012 12:17 PM
Nitro22
Oct 12, 2006 01:33 AM
