Spare Tire Suggestion
Old Oct 29, 2021 | 05:22 PM
Danielng0811's Avatar
Danielng0811
Hi,
I ordered a new 2022 JCW Countryman yesterday. In the meantime, I am researching on the spare tire options. I will use it for road trips. Of course, the most easiest way is to buy one (1) full size wheel. However, a space saver tire will be the best choice.
Any inputs, suggestions will be appreciated.
Thanks!
Daniel
Old Oct 30, 2021 | 05:27 AM
Mini-Titan's Avatar
Mini-Titan
Since you have a JCW, I'm assuming they still only come in AWD. I've been a bit concerned about running one wheel of a significantly different circumference, assuming (there's that word again!) that this causes difficulties with the AWD system.
Space savers are not even close to the same circumference. I bought new wheels/tires in the same circumference as OEM, and simply kept an OEM as my spare. Bought a scissor jack and modified the weld-clamp-holder to grab the "hockey puck" that fits into the cup on the jack points, put a 17 mm thin-walled, plastic-covered deep socket and ratchet in the under-storage area, and now can finally relax about having a flat and not having to worry about what to do.
Also, those space savers almost always ONLY fit over the rear brakes on a JCW. SO, if you have a flat front, you first have to jack up the rear and put your space saver on the rear. Then, take that rear tire and replace the front flat tire with that rear tire.
My spare is loaded face-down, so, I cleaned it up, and use the inside as my catch-all bucket (which used to be a milk crate) to hold my bike shoes, tools, gloves, etc. Although it takes up some room (compared to the milk crate), it's being used for multiple functions.
Old Oct 30, 2021 | 09:43 AM
Danielng0811
I think so! I will buy a OEM wheel tire instead of a space saver. Could you show how you store the spare tire in your Countryman back trunk? Thanks!
Old Oct 31, 2021 | 07:17 AM
Mini-Titan's Avatar
Mini-Titan
When I think about it, I'll take a picture. It's nothing fancy...just a piece of cardboard and towel underneath to cushion the wheel face from getting abraded, with a cargo-net over it and clipped to the side to keep it from sliding around.
Old Jul 24, 2022 | 03:04 PM
MIminiclubman's Avatar
MIminiclubman
Spare solution from Hedrick Mini. They had this on their website for awhile
btor
Tires, Wheels, & Brakes
Sep 26, 2012 08:46 PM
Kennedy
Nov 13, 2007 04:42 AM
minicati
Mar 30, 2007 10:16 AM
dcsmd007
May 2, 2004 01:10 AM
