R52 Convertible Top wont open past Sunroof - 2007 R52
To start with - i have read ALL the posts on this site and every site i can find about the top not fully opening / closing. I have wated the 4 videos from Tullid1 AND did everything in his video to see if anything obvious popped out. I have bypassed the two switches in the back by cutting each set of the two wires going into the switch and connecting them.
Situation. I push top open button - sunroof opens
Push button again - NOTHING happens - no flashing lights, no windows down nothing - windows dont go down, top doesn't move any more
I have confirmed that the LED light behind the top close button works because if you turn the car off with the sunroof open it blinks.
I have tried several "resets" i read (opening and closing the windows, pushing the middle lock button up for 5 seconds)
If you have ANY advice - i would greatly appreciate it -- please feel free to PM me at sandra.rose@comcast.net or reply here
Sorry for your misfortune. If you have done a thorough work through of the various sensors and their continuity to the roof control module then the module would be the next most likely suspect.
Had you seen the various roof related documents here?
http://www.ronsworld.nl/nl-NL/mini-mods/schematics
(The top goes into sunroof, then there is no flashing light or anything. I’ve checked all sensors, they should be fine. Another issue I have is the rear windows are stuck down, but if you have any tips, id appreciate them)
