R55 No start issue
Old Oct 17, 2021 | 03:48 PM
Collin Piette's Avatar
Collin Piette
No start issue
Hi, everyone.
So i've been trying to hunt down a reason why my clubby won't start, and I'm curious if i should be looking at the infamous fuse pump relay that has seemed to be an issue with most.
In the beginning when i first bought the car it ran fine. first time i really drove it for a distance it stalled several times. So I went to through motions to narrow it down. Changed the in tank filter, low pressure fuel pump, high pressure fuel pump, fuel pressure sensor. So my latest step was i purchased an OEM used sending unit put a new filter in that as well as a fuel pump. It was good deal for two fairly low mileage parts (60k). The last thing i did today was loosen the metal line from the HPFP to the rail to see if i would get a spray. Nothing and even went as far almost disconnecting it entirely. Am I safe to say that the relay thats soldered on to the stacked fuse panel dead and or have a broken solder point? Any feedback would be fantastic.
s
Old Oct 17, 2021 | 04:02 PM
A383Wing's Avatar
A383Wing
you need to clarify what your "no start" is.....engine won't turn over when key is in the start position, or.....engine cranks over but will not fire off
Did you check for codes?
Bryan
Old Oct 17, 2021 | 04:16 PM
Collin Piette
When I say no start I mean it cranks and won’t turn over like it’s not getting fuel. I’m not throwing any codes either.
Old Oct 23, 2021 | 08:12 AM
Andrewsolis83's Avatar
Andrewsolis83
I would definitely start at fuel pressure. See what your getting at the HPFP if any. If no fuel it could be the in tank pump. Both are notorious for failure
Lopanda
Dec 23, 2024 07:11 PM
BHat1Trey
Nov 19, 2019 12:53 PM
Jennifer Kintz
Sep 24, 2019 08:36 AM
Jennifer Kintz
Sep 3, 2019 06:57 AM
b14nismo
Aug 28, 2017 05:52 AM
