R56 Correct hoses for catch can install
Old Oct 5, 2021 | 08:12 AM
SkipII's Avatar
SkipII
I am installing a catch can on the turbo side of my 2013 R56S (that's the only PCV hose on that engine), but want to make sure I'm getting the right hoses. I'll be cutting into the hoses coming out of the valve cover and the one going ot the turbo. Once I cut them, I'm committed and cannot run back to the auto parts store.
I'm told I need a 5/8" (ID) PCV/fuel hoses, but an advance stop at four different auto parts stores was met by a puzzled stare. I kept telling them not a heater hose, but the only "fuel" hose they had was 7/16".
Am I right about this 5/8" spec?
Old Oct 5, 2021 | 08:19 AM
Jason Cornelius's Avatar
Jason Cornelius
don’t really need to watch the video
​​​​​​, but check his description it has a list of parts he used and Amazon links. I actually used everything he had there with no issues.
Old Oct 6, 2021 | 04:10 AM
DJ-R's Avatar
DJ-R
I ran into the same issue. Napa was the only place that had the high pressure hose in the correct size.
Old Oct 6, 2021 | 08:07 AM
SkipII's Avatar
SkipII
Actually, the YouTube was not all that helpful. I still don't know the hose size. It links ot an Amazon listing but does not give the ID of the hose.
Old Oct 6, 2021 | 08:38 AM
DJ-R's Avatar
DJ-R
5/8 is the correct size.
Old Oct 6, 2021 | 11:34 AM
DJ-R's Avatar
DJ-R
If I remember correctly mine was a 350psi hose. I think I got around 6ft for $30. Works like a champ
And I had to use these connectors to make it all work. It was a very tight fit with the stiffer psi hose, but it works and has been on my car for almost a year with no issues
Old Oct 7, 2021 | 07:21 PM
NeonLed's Avatar
NeonLed
This is what I used for mine. http://www.radiumauto.com/FuelPCV-Rubber-Hose-P567.aspx
islandguy808
Nov 9, 2024 11:34 AM
Neal3000
Sep 22, 2017 09:08 AM
phillipcoopersgates
Sep 10, 2013 07:22 PM
johnD
Sep 12, 2005 09:26 AM
