R55 Can't Remove Brake Light Bulb Holder
Old Oct 1, 2021 | 06:23 AM
crazy4trains's Avatar
crazy4trains
2013 Cooper Clubman S, 60K+/- miles
This little car is driving me nuts. Driver side brake light bulb is burnt out. A couple of minutes on YouTube and I see it's an easy change-out. No worries, right?
I remove the rear light assembly and I CANNOT CANNOT CANNOT remove the top bulb holder. The lower two twist out easily but the top one, where the brake light bulb is located, will not turn and release. I'm twisting so hard I'm worried about breaking something and the thing barely moves. It appears there may be a blob of plastic or other material on the light assembly that lines up with the notch in the bulb holder. I've poked a small screwdriver between the blob and the bulb holder but that hasn't helped at all. I've posted a couple of pics with the blob circled as well as a pic of the lower bulb holder which is easily removed. Any thoughts about what I need to do to remove the bulb holder? I can't believe something this simple is so difficult. Thanks!!!
Old Oct 2, 2021 | 12:22 AM
R55_'s Avatar
R55_
Hi - looks like something (short circuit someplace) has melted the light casing and 'glued' the twist off light holder to the main unit - try a file or a Dremel type tool to grind that blob of plastic off
Old Oct 2, 2021 | 08:18 AM
crazy4trains
I was finally able to get it free. It required a small flat-blade screwdriver aligned underneath the holder beneath the blob. Required gloved hands due to the amount of required torque. It has loosened up some so hopefully the next replacement won't be as problematic.
The other side was easy. No blob!
StillK
R55 :: Clubman Talk (2008+)
Sep 10, 2015 12:17 PM
GreekDrifter91
Sep 25, 2012 02:04 PM
TBangin23
Aug 23, 2010 10:08 PM
garic18
Jul 10, 2010 05:26 PM
mplatt911
Jul 2, 2008 05:19 AM
