Suspension Aftermarket or R53 Control Arms
Old Aug 28, 2021 | 07:18 AM
Bonestock3's Avatar
Bonestock3
Needing to replace the control arm bushings on my '03 R50, since I will be modifying the suspension anyway I figure I'll swap out the control arms altogether if better options exist.
So far no luck finding an aftermarket control arm unit, curious if the R53 control arms are any different/ have an advantage.
Old Aug 29, 2021 | 08:34 PM
OCR's Avatar
OCR
So...what is this "better" option ? Do you know what the OEM arms do, or..."don't" do ?
NOTHING better !
The big thing about the aluminum arms, is a slight loss in unsprung weight. You do know what unsprung weight is...? Just makes the shocks and springs work harder with heavier parts, than with lighter parts.
I don't understand this affection with this, so-called..."upgrading" of parts, when the questioner doesn't even understand the benefit, or the lack of.
Bone -
Make sure that your current suspension is in good condition, shocks, bushing, tire wise. Then go out and learn to drive what you have, before adding a bunch do-dads that you aren't even sure what they do, other than a talking point. Interesting thing, you many not even feel or understand what these "hot rod" parts do, or are supposed to feel like in the car, until you have some more actual spirited driving experience under your belt.
Case in point. When you drive around a city (90°) corner, do you use the brakes to slow you down ? I've found, that in about 80+% of the city corners, driving the posted speeds, you DO NOT...need to slow the car to make the corner. A Mini that has a suspension, that is, in good condition and has reasonably good tires, is VERY capable in doing this...in "stock" form.
Not trying to give you a hard time, just providing little real world insight.
Save your fancy part money, and take a driving class or two. MUCH more fun than getting all dirty laying under the car.
Mike
Old Aug 29, 2021 | 10:12 PM
deepgrey's Avatar
deepgrey
The R50 and R53 arms are the same. I believe DNA Racing in Italy still makes a set of tubular front LCAs (I assume you're talking about the front), but I know of no one who's ever bothered to buy a set.
Old Sep 1, 2021 | 07:18 AM
Bonestock3's Avatar
Bonestock3
I asked a simple question Mike, not for your opinion or impressions on my experience based on that .. very simple question. Here's a decent alternative
"Hey Bonestock, seems you are new to Mini's (classy underhand), they stock unit is made of aluminum and is so efficient there really isnt an aftermarket part that is better, maybe look at a nicer set of bushings and invest there or on something you might feel a difference- have you seen how these things handle 90 degree turns? Best of luck, happy to answer any thing else'
-Mike "
I wish you the best Mike, seems you have greater issues than my Bushings.
Old Sep 1, 2021 | 07:21 AM
Bonestock3's Avatar
Bonestock3
I appreciate your response. going to focus on the quality of the bushings then.
Old Sep 1, 2021 | 07:48 AM
veggivet's Avatar
veggivet
Changing out the shocks, which it sounds you are planning on doing, will have a much greater significance on ride quality than any change you could make with the control arms.
Old Sep 1, 2021 | 08:38 AM
Bonestock3's Avatar
Bonestock3
yes, thank you, looking through threads now to see what's a good combo with stock struts.
Old Sep 1, 2021 | 08:55 AM
veggivet's Avatar
veggivet
Bilsteins are very popular on this board, and won't lower the car.
Old Sep 1, 2021 | 03:41 PM
deepgrey's Avatar
deepgrey
Did you mean to say stock springs? If so, I think pretty much everyone who has installed Koni FSDs (I think they're called special active now?) seems to have liked them. I have no personal experience with them though. I'm running Swift springs with Koni yellows.
Old Sep 2, 2021 | 02:58 AM
veggivet's Avatar
veggivet
Agreed! The Koni FSDs transformed the ride on my R53. They weren't available for my R61, so I went with Bilstein B6s, and they made a significant improvement, though not as dramatic as the Konis.
Old Sep 10, 2021 | 07:30 AM
Bonestock3's Avatar
Bonestock3
Yes I meant springs (thank you), I did some research and ordered Koni special actives via Tirerack, looking at replacement springs but I don't want to go lower, wondering about the ride on stock springs, think i'll try it for now and see how it goes.
Old Sep 10, 2021 | 07:32 AM
veggivet's Avatar
veggivet
You'll love the ride once the Konis are installed!
Old Mar 2, 2026 | 02:48 PM
ATK666's Avatar
ATK666
Replying to an old thread, but wondering if anyone is aware of tubular front control arms for the R50/2/3? Like... in chromoly... or titanium? Can't find anything, but this seems like a gap in the market now that the first-generation cars are becoming more valuable and desirable. Maybe I need to learn how to weld.
Old Mar 2, 2026 | 03:15 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
as ​​​@deepgrey said
DNA Racing used to have some available, but i think that they are discontinued?
https://www.dna-racing.it/it/1752-co...er-r50-r52-r53
they were quite expensive & i don't think many people bought them
Old Mar 2, 2026 | 03:19 PM
ATK666's Avatar
ATK666
Oh wow, thanks for the response! Well, those pictures at least give me an idea of what's required if I go off the deep end and try to learn how to fabricate something like this myself. Not a lot of weight savings to be had there, but they look so trick!
genik
Nov 24, 2015 10:03 AM
gowest
Suspension
Jul 30, 2014 10:12 AM
Grey Shade
Suspension
Mar 19, 2007 08:49 AM
discodan
Suspension
Jul 23, 2004 11:27 AM
