R60 Oil leaks on valve cover
Old Aug 22, 2021 | 01:06 AM
simoncoopers184's Avatar
simoncoopers184
hiii everyone, I come to you because I have a problem and I would have liked your different opinions.
I have oil oozing at the valve cover as well as at the intake. I also find that my oil cap is greasy.
in my research I saw that the pcv valve could be involved and its malfunction would lead to too much pressure. i had order a new pcv valve for try.
I attach photos for you to see the problem.
Regarding the car, it is an r60 184hp with 107000 miles, i had the oil change at 103000 with 5w30 castrol edge C3.
thanks for your help
Simon
Old Aug 22, 2021 | 09:58 AM
navwizard's Avatar
navwizard
I had that problem too, and finally just replaced the cam sensor. I tried a few o-rings first which didn't work.
''if you take it out you'll see it's a bit of an odd design, the screw is off to one side of the actual sensor. I just got one off Amazon.
Old Aug 23, 2021 | 01:44 AM
simoncoopers184
first of all thank you for your answer. I note for the change of cam sensor. But is there a link with the oil on the pipe that goes to the intake of the turbo?
I will also change the pvc valve I receive today (it can not do worse I think).
last question what does this sensor correspond to?
thank you
Old Aug 23, 2021 | 03:50 AM
simoncoopers184
ok I just saw that it was another cam sensor, so I will order a new sensor to replace the leaking one, change the pcv valve, clean everything and I will come back to tell you.
blitzed310
Feb 19, 2026 09:35 AM
Billiho
Jun 3, 2019 05:44 AM
Price
May 20, 2018 05:04 PM
ShadyCoop
Sep 8, 2015 04:50 PM
Chase
Feb 3, 2008 09:08 AM
