R59 Conveneient ground connection/post inside the cabin?
Old Jul 27, 2021 | 11:50 AM
Grey Thunder's Avatar
Grey Thunder
I want to hardwire my GPS via a piggyback fuse adapter. After doing some research I found out that there is at least one ground post behind the fuse panel in the passenger side footwell. However, I do not want to remove all the trim and the seatbelt anchor. Is there a more accessible ground post in the cabin, maybe behind the kick panel under the driver side dash? Thanks!
Old Jul 27, 2021 | 01:15 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
You can land a ground wire anywhere, as long as you get a decent connection
Old Jul 28, 2021 | 11:42 AM
Grey Thunder
A proper threaded ground terminal post would be nice.
Old Jul 29, 2021 | 05:55 PM
TG.'s Avatar
TG.
I would tap into the fuse box. That's an easy one...
Old Jul 30, 2021 | 02:11 PM
Grey Thunder
For positive, yes. But the ground connections appear to be hidden behind the fuse panel and they are not accessible without removing all the plastic trim in the passenger side footwell. and the passenger seatbelt anchor. Unfortunately, I have currently a back injury and need to find a quick and easy way to do this. Or I'll wait a month.
Old Jul 30, 2021 | 03:30 PM
Capt_bj's Avatar
Capt_bj
you didn't like this answer first time around but I'll try again
remember that the entire chassis is the 'ground' .... so long as you have a clean connect to the 'body' you are connected to ground
SO virtually ANY mounting point for some other component that hits clean metal of body = GROUND
AKA drill a small hole and run in a sheet metal screw >>>> TADA >>>>> you made a new ground
Old Jul 31, 2021 | 09:57 AM
TG.'s Avatar
TG.
I'll add to what Capt bj said: It needs to be bare metal. It's obvious but paint won't make a good ground connection so if you drill a hole clean-up the paint a little around the hole before putting you fastener. Then add a little paint to prevent rust... there are many stud fasteners you can buy that makes it easy...
Personally if you'r in a hurry I would identify one of the ground wires within the fuses and buy a fuse bypass harness to tap into it. They make some you plug first instead of the fuse, and then you can put your fuse on top of it.
So many options there :p
Old Aug 4, 2021 | 02:37 PM
Capt_bj's Avatar
Capt_bj
if you drill a hole and run in a screw you HAVE clean metal to metal contact .......no way around that one .... unless after drilling the hole you paint . . .
Old Aug 4, 2021 | 06:55 PM
TG.'s Avatar
TG.
No doubt, but not a ton of surface area to make it reliable. In other words it doesn't hurt to clean it up a little while at it to avoid going back to it later...
Eric (Plug Guy)
Electrical
15
Dec 10, 2008 08:46 AM
Rick3000
Nov 22, 2007 08:23 AM
Rick3000
Nov 21, 2007 04:49 PM
MDK
Aug 13, 2007 08:51 AM
BSUCardinalfan
Electrical
Mar 30, 2007 09:03 AM
