R50/53 R53 - Noob Question... Under Cowl Drain on Driver' Side??
Old Jul 24, 2021 | 11:33 AM
Here2Go's Avatar
Here2Go
NAM Community Team
'04 R53 -
I was cleaning the engine bay and was able to clean/clear the passenger side (right), (under cowl) drain hole.
However I am unable to see a drain hole for the (left) driver side, under the cowl.
I imagine there is one but can't seem to see past/around the brake booster or wiper support bracket.
Sorry for the dumb question.
Old Jul 27, 2021 | 07:25 PM
ptkacik's Avatar
ptkacik
I’ll look but I’m sure its there.
Btw, the sun can cook the brake reservoir through that cowl grill and mine failed. I put some aluminum tape over the new reservoir to give it some UV protection.
Also, on the passenger side the rain can get into the ABS wiring and cause problems. I tie-wrapped a piece of plastic sheet over the connector “just to help the wiring harness stay dry”.
Mini’s aren’t very resistant to electrical gremlins.
Good luck,
Peter
Old Jul 30, 2021 | 09:20 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Hey @ptkacik - thanks for the additional input.
I too noticed my brake fluid reservoir looking a bit yellow and brittle.
I'm probably going to pull the airbox and plastic heat shield to see what I can find.
I'm sure there is a drain in there somewhere. If not; I'll be tapping a hole and adding a drain tube.
vulkandino
Sep 20, 2016 07:41 AM
speedman
May 10, 2016 04:46 PM
Javskies
Apr 30, 2016 10:48 PM
Mib4840
Mar 1, 2014 10:18 AM
Gareth Long
Aug 24, 2012 12:29 PM
