R50/53 Reverse gear not fully engaging
Old Jun 13, 2021 | 11:11 AM
jarred byers's Avatar
jarred byers
My reverse gear on my 2006 Mini Cooper S with 101,000 miles suddenly does not fully engage.
The gear shifter won't fall into place and it feels like something is binding. Gears 1-6 work perfectly fine. I disconnected the shift linkage on the transmission side and the gear shifter in the cabin has full range of motion but the selector on the transmission side won't fully engage reverse. I can use reverse if I hold the gear in place and ride the clutch very slowly. If I release the clutch at a normal speed, reverse will grind and pop out into neutral.
Any ideas if this is just a selector issue or an internal issue?
Old Jun 13, 2021 | 05:34 PM
RudeJoe's Avatar
RudeJoe
check the shifter cables at the transmission
Old Jun 14, 2021 | 02:56 PM
mrbean's Avatar
mrbean
Sounds like the reverse gear synchro is shot.
Old Jun 15, 2021 | 07:16 AM
AngryScotsman's Avatar
AngryScotsman
There's a synchro on reverse?
Old Jun 15, 2021 | 07:19 AM
jarred byers
I will double check the shift cables at the transmission and replace a few shift linkage parts before committing to more invasive repairs.
As far as I have looked, I do not believe there is a reverse synchro but I may be wrong.
Thanks for the replies and please mention anything else that may help/better diagnose.
Old Jun 15, 2021 | 10:23 AM
mrbean's Avatar
mrbean
Yes.
Traditionally manual trannies did not have a synchro on reverse, instead the reverse idler would slide into position to mesh with the other gears.
Synchromeshing reverse has become more and more common over the years and is used on the 6-spd getrag in the R53 (the 5-spd in the R50 does not use a synchro on reverse).
Old Jun 15, 2021 | 10:28 AM
jarred byers
Any recommendations on rebuilding with a new outlay shaft assembly and possibly input shaft assembly vs just replacing the gearbox with a used one and swapping over my Quaife LSD?
Old Jun 15, 2021 | 10:38 AM
mrbean's Avatar
mrbean
It's very difficult to find internals for these transmissions aside from bearings and seals. Best to find a replacement.
Old Jun 16, 2021 | 06:28 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Mine had the same issue. Turned out to be a busted clutch fork an throw out bearing was on its way out.
Old Jun 16, 2021 | 03:56 PM
FakeName's Avatar
FakeName
Might want to check the motor/trans mounts.
tenutso
Jul 16, 2018 07:56 AM
Jvsenerth
Jul 13, 2015 07:19 AM
kimi1964
Sep 27, 2012 07:15 PM
NorCalCooper
Oct 1, 2010 01:46 PM
chrisneal
Feb 4, 2003 06:23 AM
