R50/53 2005 R53 Overheats - CANT FIGURE IT OUT :(
Old Jun 6, 2021 | 07:54 AM
ipstack's Avatar
ipstack
So....I fill everything up with water. Fill the res tank and also (using a hose nozzle) fill the radiator from the top of the radiator bleeder screw hole.
Start the car and let it idle for a while with everything tightened u (bleeder screws closed and res cap on).
Bleed the bottom (8mm) bleed screw, bleed the top of radiator bleeder.....water seems to be flowing, no air.
Car heats up to about 194...dont see any leaks from the res cap.
Close the hood, go for a drive, drive starts out 20 to 30 mph max, then I get to a road where I can speed up to about 50.....
OBDII reader and gauge match, temp starts to climb, gets to 220 and I make it to the gas station, shut it down....top off res tank with water....
On the way home, car creeps back up to 220, then I turned the heat on and full defrost and the temperature did drop back down to about 208 and stayed there till I got home. Heat seemed to stay hot and didn't all of a sudden go to cool air)
At a loss as to where to go from here as I have basically replaced the whole damn coolant system. ANY help would be greatly appreciated.
Items I have changed:
Radiator
Water Pump and O-ring
Water pump flange and O-ring
Res tank and cap
Thermostat (verified this works by putting it in hot water and it opened up)
Low / High Speed fan assembly and relay (used part, but can now verify the low and high speed fans work)
Pics attached so you can help me focus my displeasure onto this machine
Old Jun 6, 2021 | 06:29 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
when it gets hot is the low speed fan turning on?
Old Jun 6, 2021 | 08:46 PM
jjcsnlynn's Avatar
jjcsnlynn
Temps will be higher with just water in the system. Mix 50/50 with blue coolant and try again.
Old Jun 7, 2021 | 07:04 AM
Aspen's Avatar
Aspen
not true, water will cool better than coolant.
OP, are you losing coolant? Might be your head gasket.
also a new OEM thermostat may be needed. My t-stat would open but not correctly until I replaced it.
Old Jun 7, 2021 | 07:21 AM
cooper48's Avatar
cooper48
It's fairly easy to install the thermostat backwards. Have you checked?
Old Jun 7, 2021 | 09:15 AM
ipstack's Avatar
ipstack
Honestly If I am losing it anywhere it seems to always boil out of the rest tank. I did replace the thermostat, then removed it again to test it in hot water (it passed)
I also checked compression on all 4 cylinders and they were all at 120.......
I have a borescope camera, Do i run the car, then take the plugs out to check for moisture?
Old Jun 7, 2021 | 11:35 AM
Aspen's Avatar
Aspen
that would do it.
OP you won't see coolant on plugs. You may see milkshake oil especially on the oil fill cap.
Old Jun 7, 2021 | 08:20 PM
MVPeters's Avatar
MVPeters
When cold, there should only be one inch or so of coolant in the expansion tank - it's not a header tank.
You appear to be filling & bleeding the engine & radiator correctly, though it can be difficult to get all the air out.
120 lbs psi is pretty low for compression but I expect the throttle was not held wide open - I'd hope for 150 or so. As long as they are all even it's most likely OK.
220F is OK for a running temperature in a pressurized system.
I'd siphon off the excess coolant.
Old Sep 5, 2021 | 08:16 PM
mr.r50's Avatar
mr.r50
Sorry to jack the thread if i am, but its funny as I’m reading this post and having the exact same issues, what is the easiest best and most for sure way to bleed this w11 engine , let make sure I’m on the same page as everyone
jack it up
open front screw
Take cap off , fill until thermo screw leaks out and front screw comes out,
tighten thermo screw
start car , heat on lo bleed until air pockets out .
that’s it right ? After so i Go for a spirited drive and then for me all of a sudden tank boils over and front bleed screw has nothing but air
Old Sep 6, 2021 | 06:11 PM
ChiefM's Avatar
ChiefM
Your CAT or exhaust might be plugging up. Creating back pressure and overheating the engine.
Old Sep 6, 2021 | 09:50 PM
mr.r50's Avatar
mr.r50
i figured out the problem, thought I’d post my results because almost 99% threads never end with a solution,
Puddle of water in cyl 1, ^note this is a new head gasket too^
Plug #1, plug #2
Note to self, send head to machine shop no matter how broke you wanna be doing this work so you don’t have to do it twice .
Old Sep 7, 2021 | 06:37 PM
MrBlah's Avatar
MrBlah
and what was the problem?
Old Oct 4, 2021 | 09:04 PM
ghostwrench's Avatar
ghostwrench
I'll take a wild guess: he said he replaced the head gasket and still had coolant intrusion into one of the cylinders. He then lamented not sending the head to the machine shop during the head repair.
It sounds like the engine overheated and warped the cylinder head. Since the head wasn't machined back to flat, the coolant intrusion to the cylinder persists.
Old Oct 6, 2021 | 06:12 AM
geauxturbo's Avatar
geauxturbo
I just came in to say its probably the head. Mine was the exact same. Replaced EVERYTHING and it refused to stay cool. Head kept pushing the water out and creating air pockets in the coolant system. Had head decked, new gasket, no more overheating problems.
To anyone searching this later, go to Autozone or Oreilly or Advanced and get and head gasket leak detection kit. Its just a rubber stopper on a graduated cylinder with a little hand pump. You add blue fluid to it. Follow the instructions. If the fluid changes colors to green or yellow (can't remember) you have hydrocarbons in your coolant which means the head is bad. Then you can attack the problem. If it stays blue, then you know its not the head and can look elsewhere.
Also, I couldn't get a very expensive and supposedly top of the line aftermarket aluminum coolant tank to work with the OE cap. So, my suggestion is to keep the OE style tank.
Old Oct 10, 2021 | 12:21 AM
mr.r50's Avatar
mr.r50
you are correct
Old Oct 10, 2021 | 05:59 AM
daviday's Avatar
daviday
Ouch. Good luck getting it sorted.
Have overheated several times and was always scared of this happening. Read somewhere on here that the head was relatively strong and it was difficult for this to actually happen?
Old Oct 10, 2021 | 08:13 AM
mr.r50's Avatar
mr.r50
went thru 3 heads, aluminum heads are strong but jcw heads have a slight prone to crack near cyl 1 where the 10mm bolt holds the head and timing guides
Old Oct 10, 2021 | 06:14 PM
dmath's Avatar
dmath
What year is your JCW?
Old Oct 10, 2021 | 07:53 PM
mr.r50's Avatar
mr.r50
Originally Posted by dmath
what year is your jcw?
2002
ipstack
27
Jun 21, 2021 05:01 PM
Darik67u
39
Jul 11, 2019 03:25 PM
wolfbone71
Nov 15, 2018 06:38 PM
TonyB
Dec 15, 2014 12:01 AM
rocysuja
Mar 11, 2014 09:54 PM
