NBT vs EVO and CarPlay confusion
Old May 30, 2021 | 10:01 AM
Scott2.0's Avatar
Scott2.0
Hi all, I recently bought a 2019 MCS. It has the smaller 6.5" screen. I was doing my best to avoid this post, but I need help. Am I correct in understanding that I can add a retrofit CarPlay module (like this:
Amazon Amazon
) if I have the NBT system, but if I have the EVO system, it can be enabled via a software update? How do I know what I have? My goal is to enable CarPlay as easily and as cost-effective as possible. I installed one of the retrofit boxes on a BMW in the past and it worked great, just not sure if I need to, or even can, with my current car. Thanks in advance!
Old May 30, 2021 | 12:08 PM
sb2002's Avatar
sb2002
Hi Scott. Do you have a touchscreen or not?
Old May 30, 2021 | 12:25 PM
Scott2.0's Avatar
Scott2.0
Thanks for the reply! No touchscreen. It looks like this:
Old May 30, 2021 | 07:49 PM
navwizard's Avatar
navwizard
2019 is pretty new, I'm going to guess you have one of the entrynav visual boost units, which sadly means those boxes won't work. (I agree, the boxes work well).
you could always remove the screen and see what's back there. Not hard to remove.
Dan
Old May 30, 2021 | 08:02 PM
Scott2.0's Avatar
Scott2.0
Dan
Thanks, Dan. And dang it. I was afraid of that. Is there any way I can tell what I’m working with? I have no touchscreen and the small screen. If I can’t use one of the boxes and I can’t do a software update, am I screwed in terms of CarPlay addition? Thanks again!
Old May 31, 2021 | 08:40 AM
Scott2.0's Avatar
Scott2.0
I'm told I have the BIS headunit and that there is no easy solution.
Old Jul 29, 2021 | 01:14 PM
LowEndTalent's Avatar
LowEndTalent
Same issue for a 2022.
Touch screen without factory NAV, no way to get carplay without replacing entire head unit.
I sort of knew that going in and was working with extremely limited local inventory available and needing a car immediatley.
Old Jul 29, 2021 | 01:31 PM
sb2002's Avatar
sb2002
PM’d.
Old Oct 26, 2021 | 01:16 AM
Hob Bob's Avatar
Hob Bob
Hi guys, I’m also wanting apple carplay. I’ve put a deposit down on a December 68 plate 2018 F55 1.5 petrol Cooper Classic (which I collect Wednesday). It has the colour 6.5” media, with no Nav, has parking sensors front and rear and reversing camera. What’s my best and least expensive way to get carplay, if at all?
cheers
Old Oct 28, 2021 | 02:24 PM
bluonyx's Avatar
bluonyx
I was in the same boat, I just upgraded to a larger screen, 8.8" and purchased the CarPlay MMI Prime Retrofit Box. Took about an hour to install. Still don't have touchscreen but everything works great. Still expensive but not as expensive as a complete system change and programming.
Old Mar 20, 2022 | 09:49 PM
catalyst4's Avatar
catalyst4
Do you have a link to what you used?
Old Mar 21, 2022 | 02:37 PM
bluonyx's Avatar
bluonyx
Sure...
Bimmertech MMI Prime Retrofit
Old Mar 21, 2022 | 03:07 PM
sb2002's Avatar
sb2002
For people with the BIS headunit, MMI’s are not an option as the headunit and sceeen are one piece. MMI’s basically interrupt the signal between the headunit and screen. There’s no way to install an MMI in these cars, as you can’t put the MMI between the headunit and screen.
Old Jun 12, 2022 | 07:03 PM
minimania69's Avatar
minimania69
So with this being the case, what are my options if I want to upgrade to an 8.8" from a 6.5"?
Old Jun 12, 2022 | 08:34 PM
Dragos V's Avatar
Dragos V
buy a nbtevo set and retrofit it! You will not be sorry!
Old Jun 12, 2022 | 08:46 PM
minimania69
don’t want to be “that guy” but could you point me in the direction of a set I can buy online?
was also thinking about calling a local place to see if they can help me find the parts and install.
Old Jun 12, 2022 | 08:52 PM
Dragos V's Avatar
Dragos V
this is what you need:
https://www.ebay.com/itm/17519771141...mis&media=COPY
Old Jun 13, 2022 | 03:05 AM
sb2002's Avatar
sb2002
Hi - I’ll pm you. I’m U.S. based and have parts and experience with this retrofit.
Old Aug 12, 2022 | 06:59 PM
fish0234's Avatar
fish0234
PM’d.
Same issue. 2019 f57. Touchscreen with no Nav, wanting to add Carplay.
thanks!
Old Aug 12, 2022 | 07:15 PM
sb2002's Avatar
sb2002
thanks!
PM'd
Old May 18, 2023 | 01:34 PM
Just saw this here in info to help sort it out.
https://www.northamericanmotoring.co...ce-needed.html
Old Jun 2, 2024 | 11:18 AM
Spawnr6's Avatar
Spawnr6
I have the same screen.
sb2002, i have the same screen. Bis01. Would you be able to help me retrofit carplay and navigation with 8.8 touch screen?
Thanks!
MinisINCornwall
38
Mar 19, 2025 07:51 PM
reidmefirst
Navigation/Audio
Jun 6, 2021 08:50 AM
babyk
Navigation and Audio
Mar 8, 2021 05:28 AM
rick78
Jan 10, 2021 06:26 PM
dsimon
Dec 22, 2019 11:23 PM
