Solenoid valve
Old May 23, 2021 | 09:03 PM
mikey_t's Avatar
mikey_t
Solenoid valve
I'm having an issue figuring out how to remove the front (exhaust) solenoid valve on my 2011 R60 Countryman base with the N16 engine. Everything I've read starts off by saying to remove the 10mm bolt that holds the valve in place. My has no 10mm bolt that i can see, only a T25 Torx screw. I've removed that screw but that solenoid valve isn't budging and i dont want to break it.....
Old May 24, 2021 | 03:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yeah, that’s the screw. There are O-rings on it to seal, might have to just break those loose. Might have to just wiggle it while pulling out.
Old May 24, 2021 | 11:44 AM
mikey_t's Avatar
mikey_t
I've tried wiggling and lightly tapping it while doing so but no luck so far. I dont want to break anything (given the cost of MINI parts..) but i may just have to be a little more forceful.
Old May 24, 2021 | 11:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Once that screw comes out, there isn't anything holding it in. If you have a new one on hand, just yank it out. I have replaced both mine, but I can't recall how much force was needed to pull them out.
Old May 24, 2021 | 06:29 PM
mikey_t's Avatar
mikey_t
Are the front and back solenoid valves identical?
Old May 25, 2021 | 03:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes
Old May 28, 2021 | 10:35 AM
mikey_t's Avatar
mikey_t
Got it. Just took a little extra force. Maybe I'll tackle the one on the back side of the engine while I'm feeling lucky ....
OreoSAll4
Jul 18, 2015 07:20 PM
rzermani
Jul 14, 2012 12:53 PM
JadeAnderson
Apr 1, 2012 02:08 PM
YearOneMCS
Dec 10, 2009 01:24 PM
nigelthecooper
Aug 6, 2009 07:12 PM
