R50/53 Help diagnosing some leaking issue and a sound
Old May 6, 2021 | 10:15 PM
pollito's Avatar
pollito
Hi all. Thanks for any help with this. I think this link should work regarding the sound. You’ll hear it between 3 and 4 seconds:
https://drive.google.com/file/d/1czz...w?usp=drivesdk
I read some previous posts about a similar click and I’m going to check the cv further tomorrow along with the motor mounts, but I get a click similar to others when accelerating. I included a photo of the driver side cv. Is it possible it’s not seated all way? Not sure if it looks right in the photo. I was thinking about removing the necessary components to push it in further.
I’ve got some build up around the block below the starter and I don’t know what it might be from. I replaced the valve cover gasket and oil pan gasket. I was thinking maybe this is coming from the power steering bc they’re a little dirty but it looks thick where the starter mates.
what do you guys think about what’s dried up and around the clutch fork lever? This photo and the last makes me wonder if I might have a rear main seal leak. You can see oil between the oil pan and transmission mating surface.
Old May 7, 2021 | 04:29 PM
pollito's Avatar
pollito
Any idea what that click could be in the sound file? I took a pry bar to the engine and trans and it seems firm and I can’t recreate any noise what so ever. How much radial play would be normal in the CV?
Old May 8, 2021 | 06:52 AM
ssoliman's Avatar
ssoliman
File not working. Post to YouTube?
Michaelh57
R60/R61 Stock Problems/Issues
Feb 27, 2021 11:50 PM
Scooter24
Aug 2, 2019 07:00 AM
NvMySi
Feb 14, 2018 01:20 PM
racket
May 25, 2011 01:58 PM
MtyMous
Classic Mini Talk
14
Apr 24, 2009 12:02 PM
