F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Performance drop in air filter?
Old May 6, 2021 | 07:07 PM
MaChefAi's Avatar
MaChefAi
Anyone know who makes a drop in performance air filter for a 2021 JCW F54? K&N said they don’t. 🥺
Old May 6, 2021 | 07:11 PM
stusquared's Avatar
stusquared
Eventuri ;-)
Old May 6, 2021 | 07:13 PM
MaChefAi's Avatar
MaChefAi
That’s a beautiful intake, but I’m just looking for a high flow drop in for now. The one that came stock has an extra thick padding glued onto it!
Old May 6, 2021 | 08:57 PM
chrunck's Avatar
chrunck
Have you tried AFE?
Edit: https://afepower.com/afe-power-31-10...y-s-air-filter
Old May 7, 2021 | 07:43 AM
pjsjr13's Avatar
pjsjr13
I went with the AFE dry drop in. Don't bother with any "filters on a stick" the only intake sytem worth getting if your budget allows would be the eventuri
Old May 7, 2021 | 11:35 AM
Masada's Avatar
Masada
Do you notice any difference in intake sound with the AFE?
Old May 7, 2021 | 04:00 PM
pjsjr13's Avatar
pjsjr13
A little difference. Not anything close to an intake system.
Old May 8, 2021 | 07:06 PM
MaChefAi's Avatar
MaChefAi
Originally Posted by chrunck
Based on the description and image, that doesn’t fit a 2021. I have a message out to them.
Old May 9, 2021 | 07:22 AM
pjsjr13's Avatar
pjsjr13
I'd really be surprised if Mini changed the air box on a 2021. Looking at OEM part numbers they seem to be the same
Old May 10, 2021 | 04:54 AM
MaChefAi's Avatar
MaChefAi
Based on what everyone else said, I thought so too. Went and purchased the K&N 33-3025 and was surprised as well:
Old May 10, 2021 | 06:39 AM
stusquared's Avatar
stusquared
whoops
Old May 10, 2021 | 02:59 PM
Masada's Avatar
Masada
The question is: are you looking for a slightly better sound or some performance gain? I don't think the latter would be of anything noteworthy.
Old May 10, 2021 | 06:39 PM
MaChefAi's Avatar
MaChefAi
Well the stock one comes with a separate sponge filter glued to the base. So to answer your question, yes, a little of both. I’d take a better sounding intake, a possible hp gain, and maybe even some improved consumption for $50. Seems like a no brainer to me! At the very least the engine will breathe better!
Old May 10, 2021 | 07:21 PM
stusquared's Avatar
stusquared
50hp GUARANTEED!
Old May 11, 2021 | 04:26 AM
MaChefAi's Avatar
MaChefAi
Ha! No, but i'd take 5? Anything is better than this sponge they have added to this filter!
Old May 20, 2021 | 11:56 AM
MaChefAi's Avatar
MaChefAi
Finally found someone who makes one, but there's no way I'm not spending this type of coin for 2 layers of foam and some wire! Well maybe I would....no! Maybe? ITG: https://www.ecstuning.com/b-itg-air-...15hmp-954~itg/
Old May 20, 2021 | 12:06 PM
stusquared's Avatar
stusquared
That seems wasteful, just put that $100 towards an Eventuri
Old May 20, 2021 | 01:16 PM
MaChefAi's Avatar
MaChefAi
For sure! It's way overpriced for some foam and glue! But the same can easily be said about the eventuri! If $100 is too much, then what's $1,700+? It sure is a pretty piece of kit though!
Old May 21, 2021 | 07:33 AM
Not many that make the new design drop in. Eventuri intakes are awesome and will add some style under the hood.
Old May 21, 2021 | 08:53 AM
MaChefAi's Avatar
MaChefAi
100% agree, it's a work of art, just hidden under the hood! :/ At that price point, think I may go with a drop in filter that may give me 5+/- hp, plus a racechip that gives me 20-30 hp. Will give me 2-3x the hp for 1/2 the price. And maybe I'll use some of the left over $$ to get a charge pipe and down pipe. @ECSTuning do you carry those pipes for a 2021 JCW Clubman?
Old May 21, 2021 | 12:26 PM
https://www.ecstuning.com/Mini-2021-...ngine/Intake/4
Here we have them. ^^
Race Chips here: https://www.ecstuning.com/b-race-chip-parts/v-mini/
+37 hp and 30 lbs-Ft
The BMC filter is here: https://www.ecstuning.com/Search/SiteSearch/FB01091/
Old May 21, 2021 | 12:32 PM
MaChefAi's Avatar
MaChefAi
Thanks for the links! These look awesome! Do you happen to have any performance spec's on those pipe replacements? I heard if not the correct size for the engine, it can actually be a bit of a detriment at lower RPM'S. Any insight?
Old Jun 30, 2021 | 08:28 AM
MaChefAi's Avatar
MaChefAi
Wanted to come full circle on this. I ended up going with a BMC drop in filter rather than the ITG foam one for $110. Still spent a bit more than I wanted, but just couldn't bring myself to spend that type of money on some foam. Intake sounds a bit deeper now.
Old Jul 2, 2021 | 02:08 AM
frozenwaffles's Avatar
frozenwaffles
What are you actually basing this on? Just the looks of the sponge or real-world test data...???
Old Jul 2, 2021 | 05:19 AM
MaChefAi's Avatar
MaChefAi
Oh boy, your question is like opening a can of worms! I think conventional wisdom suggests, the more cold air going into an engine, the more efficient it will run. In turn, producing more power. Here's a great video (love this guy), comparing stock filters vs a high performance. He tests both on the dyno as well as "real world" using a vbox:
I suggest watching the whole thing, but if you're just interested in the results, check around 6:05 for the dyno numbers and 10:40 for "real world" results.
