Electrical problem window module question
Old Apr 20, 2021 | 11:09 AM
ramapo's Avatar
ramapo
Had no idea changing a dead battery on my 2010 (R56) base mini would cause so many problems. Electric window computer module now no good due to me changing battery. Mechanic who registered battery (had no idea) said replacing window module very expensive and part only available through Mini dealer, have to have the correct software to install it, etc etc. Any fairly inexpensive alternatives to fix this problem or do I have to go to the dealer and pay a fortune? Any help appreciated.
Old Apr 20, 2021 | 03:30 PM
cpmetz's Avatar
cpmetz
He probably means the FRM. You can get one at the junkyard or on eBay, and then need to code it to your vehicle. For that you need a cable and a CAN diagnostic cable.
Pretty sure there are some threads around if you look for FRM
Old Apr 22, 2021 | 02:42 PM
ramapo's Avatar
ramapo
FRM Module
OK, did some research. FYI-any Mini that is < that 10 years old and has less than a certain amount of mileage can have the FRM module replaced by a dealer for free. Unfortunately even though mine had under the mileage limit, it's a 2010. Found a few companies that rebuild Mini FRM modules (for around $200), and it's plug & play. As it's your original unit, no software needed to install. Will be sending mine out tomorrow. Anyone ever had theirs rebuilt and recommend a company? Found a couple in CA and one in PA.
Old Apr 23, 2021 | 06:26 AM
MiniToBe's Avatar
MiniToBe
I work on these FRMs and based in philly. Send me a pm for details. My price much less than 200.
Rhendy
Sep 15, 2022 02:59 PM
makeitmini
May 12, 2020 09:33 AM
Pollege96
Apr 15, 2018 04:48 PM
Pollege96
Feb 24, 2018 06:07 PM
frankiev
Sep 20, 2016 07:12 AM
