R58 Tell me about oil catch cans
Old Apr 16, 2021 | 06:18 AM
maarp's Avatar
maarp
I've read a bunch of stuff about oil catch cans - are these a necessity on the N18? I don't like the thoughts of having to do a walnut cleaning periodically.
So my questions are:
1) Is an occ still a strong recommendation?
2) Is there a particular brand that seems to work/fit better than others?
3) Without occ, how often is a walnut blast required?
TIA
Old Apr 16, 2021 | 09:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Read through this thread:
https://www.northamericanmotoring.co...arbon-fix.html
Old Apr 16, 2021 | 09:24 AM
maarp's Avatar
maarp
^ Ok, so #1 answered. Lol. Lot's of information about what happens without an OCC. Not pretty.
Now, how about #2 and 3?
Old Apr 16, 2021 | 09:27 AM
MiniSMan's Avatar
MiniSMan
Reading through the Thread.. I believe you need a Walnut blast done on an N18 engine every 50,000 miles ....
Old Apr 16, 2021 | 09:30 AM
maarp's Avatar
maarp
Thanks - With or without OCC? I got lost in the details. I'm no mechanic.
Old Apr 16, 2021 | 11:00 AM
Jason Cornelius's Avatar
Jason Cornelius
If you look through the classifieds there might be one for sale. I know there is a BSH OCC listed on Facebook market place located in Columbus, oh FYI.
Old Apr 16, 2021 | 12:05 PM
mountainhorse's Avatar
mountainhorse
As much as anything to keep IVD’s to a minimum .. oil selection. Is tantamount to a clean intake tract .
in particular ... an oil that has low volatility and will vaporize to a lesser degree To get swept up on the POV system to start with A part of the puzzle.
Look for anything that has a NOAC number of less than 7 IMO ... and stay away from ‘0W’ or 5W-20 oils unless you live in the arctic or sub zero conditions.
Im running full synth Redline 5w-30 for these reasons now. NOACK of 6.
Factory MINI oils, most diesel oils, 0w oils, have NOACK numbers over 10. In a high quality lubricant ... like these and some others.. I’m not concerned if they didn’t pay BMW for their ‘LL’ certIndicating unless I’m worried about warranty compliance (warranty doesn’t cover IVD’s In most cases BTW )
Occasional (every 20k mile) GDI cleaning services like the BG-Chemicals one ... are easy and not expensive ways to keep the system cleaner.
Once ‘coked’ up with heavy/hardened IVD’s ... blasting seems to be the the only way to clean them ... and really should be directly followed up with a chemical cleaning regimen as a ‘mop up’ to clean the valve seat lands that aren’t touched by the blasting.
on the N18’s ... I don’t think an OCC is necessary if you use oil with low volatility... and your motor does not have abnormal blow-by. I can’t think of a situation where an OCC would ‘hurt’ though.... but many designs will not catch lighter vapors
my 2¢
Old Apr 16, 2021 | 12:32 PM
maarp's Avatar
maarp
^ Interesting, thank you. I'm fascinated by this NOACK rating. Here's a thread from a couple of years ago. Apparently Amsoil does everything but bring you coffee in the morning.
Old Apr 16, 2021 | 01:39 PM
mountainhorse
My take ... IMO...
The quest for oil info is a deep dark rabbit hole filled with personal biases, misinformation, too much tech for people to digest well
Much of it you don’t really need to understand though as long as it is a top quality product from a reputable MFG.
Low NOACK numbers are a simple way to say that the oils don’t loose much to evaporation (aka ‘boil-off’) ... and thus don’t get suspended in the PCV stream being sucked back into the engine... causing IVD’s, coting of intake tracts with oil residue, dirty piston crowns ... and more oil consumption.
One other thing to remember ... as Thad oil ‘boils-off’ ... it changes the properties of the oil... and it’s abilities to act as a good lubricant over time... a poor but pointed analogy is should that has cooked too long becomes ‘stew’
Yes, the engines MUST have good lubrication... AND ... GDI’s must have oil that works WITH not against the design (low evaporate losses)
Amsoil has their Signature-Series Synth 5w-30 AKA, ‘ASL’) at 6.7% NOACK ... and their European formula (AEL) at 7.1%
Redline has their High-performance Synthetic and European-formula 5w-30 both at 6.0% ... so I’d say they are comparable... I’d run either actually ...I get the best price on the Redline.
I can do an oil change with filter and a can of gas treatment for less than $100 ... but I’d be hard pressed to find a shop do it with these oils and OEM filter for that price ... most shops only use ‘their’ oil (good margins) and will argue that it’s the best ... and tell you that you should not believe what you read on the ‘interweb’
Ive only met one mechanic that actually knows what ‘NOACK’ numbers are... much less what the numbers are on the oil they are using ... they usually default to saying ‘This oil we use meets the tough BMW LL01/04 standard 😬
both are NOt BMW LL01/04 certified.. but both ARE engineered to meet AND exceed this spec... I would assume that don’t want to pay BMW the big bux for their ‘blessing’
I read somewhere that the factory Mini/BMW 5w-30 oil is at around 12% NOACK .
BTW... IVD = Intake Valve Deposit
Good piece on NOACK and volatility.
https://www.amsoil.com/newsstand/aut...ts-volatility/
Old Apr 16, 2021 | 02:09 PM
MiniSMan's Avatar
MiniSMan
Originally Posted by mountainhorse
My take ... IMO...
Redline has their synth 5w-30 at 6.0% ... so I’d say they are comparable... I’d run either actually and o get the best price on the Redline.
So basically your saying the BEST oil to run in an N18 engine or in a MINI is REDLINE Brand 5w-30 Full Synthetic at what intervals ? I would think every 7,500 miles or possibly every 5,000 miles to always have fresh oil ? Whats your recommendation ?
Old Apr 16, 2021 | 02:15 PM
mountainhorse
I CERTAINLY will not tell another enthusiast what THEY should run ... that is too hot of a topic on ANY enthusiast forum/group .
just what I run and my reasons for running it in my car...
I’d run either of those two brands of oils in my own GDI cars.
I’d lean towards the Redline for reasons of cost in my area.... and I like to stay consistent as much as possible with what I use in each car.
I change my oil every 5000-miles or 1 year ... whichever comes first...
good ‘insurance‘ for the money...
Old Apr 16, 2021 | 02:17 PM
maarp's Avatar
maarp
I gotta say I like the idea of the low NOACK number to reduce the need for a catch can. From what I've seen, occ's run about $375 USD, which equates to $4M CAD. :D
Old Apr 16, 2021 | 02:24 PM
maarp's Avatar
maarp
What the hell?!? Drive the damn thing!
Old Apr 16, 2021 | 04:03 PM
mountainhorse
Which one??
MAARP....
How many miles on your car ?
What oil has been used in the past? [weight/brand/type]
What were the oil change intervals?
Has your intake system been cleaned and/or valves been blasted?
Old Apr 16, 2021 | 07:51 PM
maarp's Avatar
maarp
MAARP....
It just rolled over 90K km (~55K miles). The PO was changing every 12K km (7K miles) using Castrol full synthetic, 5W30. I don't think it has been blasted - he gave me the service records and there is no mention of that.
Old Apr 16, 2021 | 08:52 PM
mountainhorse
With that low of mileage... and you have an N18... I'd bet you have minimal deposits...
I would go with a good chemical clean (professional service) though for good measure and start using an oil with outstanding NOACK numbers... And I'll bet you're good for triple that mileage.
Old Apr 18, 2021 | 06:22 AM
maarp's Avatar
maarp
One more thing before I go....what's the oil capacity? It's not in the manual, and I can't find it on the web.
Old Apr 18, 2021 | 06:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I buy the 5 quart jugs and dump the whole thing in. Puts the level just above the high mark, which hasn't given me any issue.
Old Apr 18, 2021 | 10:55 AM
MiniSMan's Avatar
MiniSMan
4.4 quarts
Engine Oil
4.4 quarts. . (with filter)After refill check oil level.
2013 Mini COOPER (1.6L 4 -cyl Engine Code N18B16C N ...
https://www.amsoil.com › ... › Auto & Light Truck
nels415
Apr 20, 2016 12:05 AM
Whitt
Feb 9, 2014 01:18 PM
freeskier
Mar 18, 2008 05:05 PM
cnhoward
Aug 1, 2007 04:24 PM
