F55/F56 Enabling rear fog lights: VO change
Old Apr 10, 2021 | 06:49 PM
Mcburwell's Avatar
Mcburwell
I am working to enable rear fog lights on a 2021 F56 Cooper. This has been covered in the past elsewhere in the forum. I have replaced the panel light switch with the version having a rear fog light button (step 1). The next step is to add the rear fog light option (5AA) to the VO. Up to now I have only used Bimmercode to alter coding. It would appear that that app does not have the ability to change the VO. Is that right? If so, do I have to jump to E-SYS to do this? Or is there a different preferred coding app?
Old Apr 12, 2021 | 09:26 PM
BlazingRed_F55's Avatar
BlazingRed_F55
In bimmercode you can activate your fog lights by enabling this:
Head over to LCE Master
Then set NSL_Verbaut to Verbaut
This should be all that you have to do if you've already installed the physical panel with the button to turn on rear fogs.
Old Apr 13, 2021 | 11:39 AM
Mcburwell's Avatar
Mcburwell
Excellent. Very helpful. You pointed me in the right direction. In fact there are four more changes to make after the one you suggested. The whole list of required changes is:
Body Controller>Expert Mode>
LCEmaster changes
LCELampMapping3 changes
Mapping_Nebelschlussl_L_ouput to nsl_l
Mapping_Nebelschlussl_L_Function to nebelschlusslicht
Mapping_Nebelschlussl_R_output to nsl_r
And then Voila! I have functioning rear fog lights.
Bloody marvellous. Many thx indeed
Old Apr 13, 2021 | 11:42 AM
Mcburwell's Avatar
Mcburwell
Whoops. Cut-and-paste error. The corrected code changes are:
LCEmaster changes
>> Mapping_Nebelschlussl_R_Function to nebelschlusslicht
Still marvellous.
Old Apr 14, 2021 | 08:24 AM
Jon Roberts's Avatar
Jon Roberts
What is the part number for the light switch that works?
Old Apr 14, 2021 | 09:28 AM
Mcburwell's Avatar
Mcburwell
The switch assembly with the working second (rear) fog light button is Mini/BMW part number 61319865845 I bought mine from here: https://www.ecstuning.com/b-genuine-...h/61319865845/ Quite expensive ($183) from there, but it is a new BMW part. As my Cooper is brand new I wanted to get a new, official part. If that is not for you, then you will find them cheaper on the web, particularly on ebay.
I should also note that on a 2021 model the switch snaps-in to its position on the dash knee panel. Look at the four wedge-shaped retainer lugs on the new part and you will see where to gently pry on the dash retaining clip to release the switch. No major surgery needed. Earlier versions of the part were held in with torx screws, which are now missing (they are always looking to save cost...). However, the part still has mounting holes for the torx screws, in case you are fitting to an older model
Good luck
Old Apr 14, 2021 | 09:30 AM
Mcburwell's Avatar
Mcburwell
It is illegal in the US to have two active rear fog lights. One light is legal. Up to you if you activate one or two lights. To have only one active light just don't make the code change listed above for the light (left or right) to leave it inactive.
Old Apr 14, 2021 | 01:24 PM
TVPostSound's Avatar
TVPostSound
It is NOT illegal to have 2, but if you have one it must be on the drivers side.
Here's California
A vehicle may be equipped with not more than two red fog tail lamps mounted on the rear which may be lighted, in addition to the required tail lamps, only when atmospheric conditions, such as fog, rain, snow, smoke, or dust, reduce the daytime or nighttime visibility of other vehicles to less than 500 feet.
When two lamps are installed, one shall be mounted at the left side and one at the right side at the same level and as close as practical to the sides. When one lamp is installed, it shall be mounted as close as practical to the left side or on the center of the vehicle
The lamps shall be mounted not lower than 12 inches nor higher than 60 inches
The edge of the lens of the lamp shall be no closer than four inches from the edge of the
lens of any stop lamp.
Old Apr 14, 2021 | 05:59 PM
Mcburwell's Avatar
Mcburwell
Thx for that info on legality. I can sleep straight again (I activated both of my rear fogs).
I wonder why the dealerships don’t offer activating the rear fogs as a (paid) option? Would be a high margin way to make money from new owners like me...
Old Apr 15, 2021 | 05:18 PM
TVPostSound
Me at service entrance:
"What?, you want me to pay to activate something that's already there??"
Old Apr 16, 2021 | 05:53 AM
Mcburwell's Avatar
Mcburwell
Sadly, that is now the way of the world. For some years now, if you buy a 30MHz oscilloscope from Tektronix you can, for a fee, turn it into a 60MHz scope (40% more expensive off-the-shelf than a 30MHz unit) with just a software upgrade. No hardware changes at all.
Old Jan 22, 2025 | 02:53 PM
Canac's Avatar
Canac
Mini Cooper 2020 non S base rear fog Light on
LCEmaster changes
Still marvellous.
Hi Mcburwell!
I want to thank you for your rear fog Light code. IT Works for a mini Cooper 2020 non S base.
Do you have a code for the front fog Lights? I took off the DRL Lights and put fog Lights but IT does not Works.
Thanks.
Old Jan 24, 2025 | 06:26 AM
Mcburwell's Avatar
Mcburwell
Canac, sorry to say I cannot help with the code changes for front fog lights. The rear fog light code above came from a web search for it rather than be creating it from scratch. I would suggest a thorough search yourself. You will not be the only person who has done this. Good luck.
Old Jan 24, 2025 | 08:15 AM
Canac's Avatar
Canac
Thank you so much for your reply.
Once I've found the code, I'll put it in the forum.
scottwrightF1
Sep 13, 2013 04:14 PM
Mendenheezy
Jun 28, 2008 01:12 PM
Eric (Plug Guy)
Jun 1, 2008 04:00 AM
Bikeguy57
Feb 2, 2005 09:25 AM
Pebbles
Mar 1, 2003 04:20 PM
