R50/53 Used Gen 1 JCW Spoiler attachment
Old Apr 6, 2021 | 12:18 PM
Johnmini1's Avatar
Johnmini1
Hi! New here, I have an R53 and just acquired a JCW spoiler. Suggestions for attachment? Heavy duty 3M tape, Windshield sealant? I did a quick search but found nothing.
Thanks in advance!
Old Apr 9, 2021 | 05:50 AM
ramjet77's Avatar
ramjet77
Do an Amazon search for 3M automotive adhesive trim tape. Many widths and parts descriptions will pop up so you have a lot of options. Or go to any parts store; they have it.
Old Apr 9, 2021 | 06:55 AM
Johnmini1's Avatar
Johnmini1
Thanks! I thought 3M Heavy duty would work, the stuff that holds the original wing on is a tape and super strong. Just wanted to make Sure it wasn't going to fly off!! Probably not a lot of downforce going on.
Old Apr 9, 2021 | 07:12 AM
kaneguy's Avatar
kaneguy
Hi Johnmini, Here is the Mini's official installation doc for the JCW spoiler. I've done the same mod to my 2004 MSC a few years back and it works great. I used the adhesive listed on the doc. I wouldn't use any tape products because over time the the pressure and heat will weaken it.
File Type: pdf
PoonRacing's Avatar
PoonRacing
factory use epoxy to glue it.
https://www.realoem.com/bmw/enUS/sho...diagId=03_1786
Old Apr 9, 2021 | 08:58 AM
RB-MINI's Avatar
RB-MINI
The stock spoiler is bolted to the hatch along with the tape. The JCW spoiler will probably fly off with tape only.
Old Apr 9, 2021 | 11:43 AM
Johnmini1's Avatar
Johnmini1
Thanks for all the replies to my first post! Looks like adhesive, I don’t want a fly away! Lol!
Old Apr 9, 2021 | 12:09 PM
OCR's Avatar
OCR
This stuff is almost permanent -
https://www.scientificindustries.com...CABEgLkifD_BwE
And thick enough to protect the body metal/paint from any damage from the wing moving around.
Mike
Old Apr 9, 2021 | 12:19 PM
Johnmini1's Avatar
Johnmini1
Oh no! Tape again! I see the BMW guys use it but they have trunk mounted spoilers. I definitely don’t want it flying off! Seems like everyone has had success with both! Is it just a permanent vs removable thing?
Old Apr 9, 2021 | 10:20 PM
OCR's Avatar
OCR
No, no, like the factory...both adhesive tape AND mechanical fasteners.
Mike
Old Apr 10, 2021 | 06:53 AM
kaneguy's Avatar
kaneguy
Mike
Totally in agreement, Do not use tape!!!! The OEM JCW wing spoiler is attached only with adhesive, there is no mechanical screws. That is why they used a strong epoxy to attached it, so it doesn't go anywhere. And yes it is a permanent bond but the wing can be carefully removed with piano wire.
Old Apr 10, 2021 | 06:56 AM
Johnmini1's Avatar
Johnmini1
Awesome! Thank you everyone for the replies! I'm ordering the epoxy today, looks like the best route to go. I'll post a photo of it when it's done. Thanks again!!
Old Apr 11, 2021 | 07:12 AM
Johnmini1's Avatar
Johnmini1
So the Betalink K2 that is suggested by Mini is no longer available, any suggestions for an alternate adhesive? I see a Betalink 1K available.
Old Mar 18, 2024 | 01:08 PM
R53hyperblue's Avatar
R53hyperblue
Also want to know what glue recommendation to reglue my JCW Wing ? instead of the Betalink
Old Mar 19, 2024 | 07:40 AM
+1 my vote is for OEM betalink, you don't want to loose that rare JCW spoiler
Old Mar 21, 2024 | 06:12 AM
slofut's Avatar
slofut
Amazon Amazon
https://www.autobodytoolmart.com/pro...d80afb7c3f0491
Used by body shops all the time, many different types. Go to autobody tool mart and ask questions, or go to a local body shop and ask questions, they can surely help and it would be local to you. OEM is likely rebranded 3m.
Old Mar 21, 2024 | 08:53 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Similar to @slofut 's (Epoxy) suggestion above -
In my former (SFX) industry ; Plexus MA (methalacrylate) was our go to industrial solution where a superior mechanical attachment was necessary but not possible.
Plexus It is not epoxy but mixes like epoxy by ratio via the gun operated dispenser. It's impressively strong!
Sets up fast, toxic smelling as heck / the fumes are overwhelming. Use in well ventilated environment.
Although I don't recall formula # we used;
Amazon Amazon
sells a few consumer grade versions for a variety of applications and cure times.
*Be sure to purchase a kit with the dispenser gun!
MiniLynsk
Jul 7, 2018 10:07 AM
DK94
R61 :: Paceman Talk
Oct 29, 2016 11:06 AM
Mar 12, 2015 01:42 PM
Conrad_Thomaier
Jan 28, 2014 01:48 PM
MightyNuts
R55 :: Clubman Talk (2008+)
37
Mar 25, 2012 11:29 AM
