R50/53 Bilstein Strut Installation- Cannot Reinstall Ball Joint
Old Mar 20, 2021 | 05:52 PM
cali06R50's Avatar
cali06R50
Hello all, I have a 06 R50. I installed some Bilstein shocks, lowering springs and vorshlag adjustable camber plates.
I removed the control arm ball joint from the bottom of the knuckle and also the steering tie rod to get more freedom to get the strut in (which took a lot of persuasion!). Finally after some cussing and hammering I got the strut into the knuckle and tightened the pinch bolt.
HOWEVER, the knuckle now sits a few inches too far outboard to install the ball joint. The strut does not have enough movement to get the knuckle over to the lca ball joint.
I double checked the orientation of the camber plate and it is fine.
If I jack the knuckle will it move inboard? I tried that a few times but could not keep it from sliding off the jack and there is not a good place to place a jack :(
Should I install the tie rod and then jack the knuckle?
I welcome all advice!
Old Mar 21, 2021 | 08:30 PM
ssoliman's Avatar
ssoliman
The sway bar needs to be loose on both ends iirc
Old Mar 21, 2021 | 08:47 PM
cali06R50's Avatar
cali06R50
The sway bar is already disconnected.
I am thinking of connecting the out ball joint and steering tie rod before tightening the top of the strut on the camber plate. The camber plates are adjustable so I am thinking they might have to be loose to locate the ball joint.
I hope I am able to slide it enough on top. It is such a pain though because there is not a good place to jack up the knuckle :(
Old Mar 21, 2021 | 09:17 PM
deepgrey's Avatar
deepgrey
Something seems fishy. I didn’t need to remove the ball joint to change my struts, and I don’t recall having issues with the bottom being too far outboard.
Old Mar 21, 2021 | 11:10 PM
cali06R50's Avatar
cali06R50
I know :(
The only thing that come to my is the adjustable camber plates and the fact that the springs are different length than stock.
Old Mar 21, 2021 | 11:25 PM
deepgrey's Avatar
deepgrey
Originally Posted by cali06R50
I know :(
That shouldn’t matter. I also have Vorshlag plates and lowering springs.
Old Mar 25, 2021 | 07:01 PM
ssoliman's Avatar
ssoliman
Agree something is off
some pics?
Old Mar 26, 2021 | 09:07 AM
Zsm's Avatar
Zsm
Is your CV half shaft hyper extended, preventing you from lining up the spindle and outer ball joint? Agreed, you don't need to separate ball joint to remove strut.
Old Mar 26, 2021 | 01:35 PM
cali06R50's Avatar
cali06R50
I think this might be true :(
i didn’t need to separate my ball joint from the spindle to remove the strut. I separated the two in order to line up and make it easier to get the strut in the knuckle. But I think you may be right. I am worried that I may have done something to the cv half shaft while wrestling with the knuckle :(
Racingguy04
11
Dec 13, 2019 08:49 PM
sprp85
Jan 25, 2009 12:34 PM
Mike P
Jan 14, 2008 05:28 PM
latte hiatus
Dec 19, 2005 12:25 AM
