R55 Roof Rack Help
Old Mar 9, 2021 | 06:51 AM
tlctn's Avatar
tlctn
Roof Rack Help
My '12 R55 does not have roof rails. I found a base support rack on ebay that is supposed to fit the R55 (my dealer says it fits sedans only, but I don't think that is right). I watched a YouTube video on how to install the rack, and I could find only one of the mounting points under the weather seal. The video says to feel along the seal for perforations, but I was only able to find the one on the driver side, rear.
Can someone that has the rack please measure the distance from, say, the A pillar corner to the front leg of the support, then to the rear leg. That should give me an idea of where to expect to find the mounting points.
Thanks!
Old Mar 9, 2021 | 08:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I have the OEM rack on my Clubman. The slots in the weather strip were difficult to find, even with the measurements. I should be able to get measurements this afternoon, if someone else doesn't before then.
Old Mar 9, 2021 | 12:46 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
OK, I have some measurements for you...
From the front corner of the door window to the middle of the rack mount is about 10.5"
From the middle of the front rack mount to the middle of the rear rack mount is about 30"
Old Mar 9, 2021 | 06:33 PM
tlctn's Avatar
tlctn
Perfect! Thank you very much. That is exactly what I was looking for!
Old Mar 13, 2021 | 07:31 AM
tlctn's Avatar
tlctn
I chickened out and had a local indy do the roof rack installation. I could've done it, but I did not feel comfortable cutting into the weather seal. I am 74 years old, and I have had lots of experience turning 30-minute jobs into 5-hour ordeals on motorcycles and automobiles
One question I have - it looks obvious that water can get into the weather seal at the roof rack mounting points. Is that a problem? Where does that water go?
In addition to being old, I am ****!
Old Mar 23, 2021 | 08:24 AM
veelangs's Avatar
veelangs
mine came from the factory and i've had zero issues with water from there
unless the indy bodged the cutting i'd imagine it tucks in nicely and seals
Old Mar 30, 2021 | 03:35 AM
spiney's Avatar
spiney
I put the rack on ours in 2013 and took it off in 2020. The car lived outside in New England that whole time in rain, snow, whatever, and not a drop of water or any rust on the car when I took it off.
Geordie2008
Sep 18, 2018 12:36 PM
wabiker3576
R55 :: Clubman Talk (2008+)
Jan 12, 2015 07:04 AM
SchHDogs
Jun 13, 2013 10:11 AM
Mark Quarum
Oct 27, 2009 01:45 PM
sambusik
Dec 13, 2003 07:55 AM
