R55 Roof Rack
Old Dec 29, 2014 | 11:14 PM
wabiker3576's Avatar
wabiker3576
Roof Rack
Has any one used the Yakima Control Tower and Landing Pad on a Clubman ? I am looking at several R55 but none of them have the factory roof rails and I prefer a Roof mount vs a Hitchmount
http://www.yakima.com/shop/racksyste.../control-tower
http://www.yakima.com/shop/racksyste.../landing-pad-1
http://www.yakima.com/shop/racksyste.../landing-pad-7
Old Dec 30, 2014 | 04:30 PM
Minime1963's Avatar
Minime1963
I'm looking for a yakima roof rack as well. Doesn't it take the Q towers, clips, and 48" crossbars? I already have yakima raptors bike mounts, so I want to stick with yakima brand rather than Mini.
Old Dec 31, 2014 | 08:38 AM
daddyandmadi's Avatar
daddyandmadi
I have the permanent mounts on my clubbie. Not sure how much the install is now, but nice to have an easy to install bike rack. Did you look at ecstuning for the mini base system?
Old Jan 1, 2015 | 08:48 AM
Minime1963's Avatar
Minime1963
I read on one of the posts somewhere that the Mini Brand roof mounts didn't have the adjustability that Yakima and Thule have. In other words, different racks need to have different spacing. I know that when I go from my Yakima Raptors to my Yakima Rocketbox I have to adjust the amount of spacing.
Hopefully that made sense.
Old Jan 1, 2015 | 09:42 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Not True. It's the accessory top which has the adjustability. Once the Base Support System is in place and properly secured, no adjustments are required between accessory top components being installed.
Case in point. First generation MINI Base Support Systems are permanently drilled into the roof tops, not attached to side rails. Yet these Base Support Systems utilize all the same top components as the other models do.
MINI systems also carry two year warranty needing only to be dropped off for replacement due to defect, no back and forth shipping or RO#s required.
Old Jan 1, 2015 | 07:57 PM
daddyandmadi
My base system is permanently installed. My Thule cross braces slide to accept my bike rack or ski box. I can install either in under 5 minutes. Also handy for home depot runs....
I feel better about the permanent mounted rails not being able to come off if I drive spirited while tooting the bikes
Old Jan 12, 2015 | 07:04 AM
+1 with what gray raven said on the mounting.
"R55 but none of them have the factory roof rails"
There is two types with the Clubman:
Roof Rails Yes : 82710435867
http://www.ecstuning.com/Search/SiteSearch/82710435867/
Roof rails : No , then gutter mounted. 82712149225
http://www.ecstuning.com/Search/SiteSearch/82712149225/
More Clubman items here: Like the Rockymount Euro Pitch Forks
http://www.ecstuning.com/Mini-2008-Cooper-R55-S_Clubman-Coupe-L4_1.6L_N14B16A/Exterior/Roof_Rack/
RobbyD
Jan 29, 2019 01:22 PM
jeri534
Nov 6, 2015 01:40 PM
krohm
Sep 28, 2015 12:16 PM
pkillur
Sep 26, 2015 01:57 PM
simron
Sep 23, 2015 10:02 PM
