Cel
Old Mar 8, 2021 | 02:34 PM
iXMrBulldopsXi's Avatar
iXMrBulldopsXi
Cel
I've purchased a n12 base model from 2007. I've been working on fixing it but I have cleared about a dozen codes and it looks like I have 4 left now.
P173b-unknown
P113b-unknown
P0117-ECT sensor 1 circuit low
P0030-H02S 11 heater control circuit
Any help or advice with these codes would be a wonderful help as I'm about ready to fill this car up with tannerite and put it out of its misery.
Old Mar 9, 2021 | 03:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
From a quick google search, 173b appears to be related to coolant temperature sensor, and 113b appears to be related to the MAF sensor.
My short list would be: replace coolant temp sensor, replace MAF sensor, and replace O2 sensor.
Old Mar 9, 2021 | 06:08 AM
iXMrBulldopsXi
Just replaced the maf sensor yesterday with the same oem model number part. Also found out the coolant temp sensor plug has been basically ripped off the wiring harness. So I need to find someway to splice a new connector into it.
Old Mar 9, 2021 | 06:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Some OBD codes will remain until a clean drive cycle has taken place. If you JUST replaced the MAF and the code remains, I would just give it some drive time. However, it sounds like you can't complete any drive cycles due to other issues that need to be taken care of.
Old Mar 9, 2021 | 08:39 AM
iXMrBulldopsXi
You're absolutely correct. Person I bought the car from used brute force with everything he did to the car for maintenance. So I guess I'm going to the scrap yard to get some plugs
MiniClubbie
Apr 7, 2020 07:54 PM
WifesMiniIsAlwaysBroken
Jan 14, 2020 04:00 PM
jnicho
Apr 14, 2017 10:10 AM
Jesperss
Jan 24, 2013 10:43 PM
Jesperss
Oct 30, 2012 07:41 PM
