R50/53 Help resetting EWS
Old Feb 17, 2021 | 04:25 PM
Pablo Chois's Avatar
Pablo Chois
Help resetting EWS
Hi,
I'm new to the forums and need some help troubleshooting my car. This is my first Mini, '06 Cooper S. I bought it cheap because it doesn't start. I did the basic checks and it cranks strong but has no spark. I did several searches here and figured it was an EWS that was out of sync. I used several threads to install INPA, purchased a
K + Dcan cable K + Dcan cable
, and jumped pins 7 - 8. I'm able to read some parameters from the car. I can see the EWS fault, but I can't reset it. This is what I'm seeing:
For some reason, there are some body modules that it won't read, I get the same error. I can see the VIN, I can see the TPS working properly. The BCM has some corroded pins but everything inside the car works so that shouldn't cause the no spark issue (I'm working on fixing that separately).
I don't think it's a software issue since I'm able to communicate with the car, I thought it was because I didn't jump pins 7 - 8 but nothing changed after that. Any ideas or someone in the Tampa area that can help me?
Old Feb 19, 2021 | 04:47 AM
Pablo Chois
I have verified that the ECU is the stock one (VIN matches), placing an order today for map and tmap sensors to rule them out.
I've been told that INPA won't be able to reset the EWS, maybe because it's a 4.3? Still unclear if it's a software issue, config issue, or an issue with one of the modules.
I ordered an AK90+ kit so I can verify the key is properly coded to the EWS, but won't be here for a few weeks.
Any insight into the problem is greatly appreciated.
Old Feb 19, 2021 | 12:17 PM
adriancl's Avatar
adriancl
If have INPA working , try this-sorry for bad video quality.
It can happen when the car runs out of battery for a long time, or when the battery is disconnected from the car many times.
Old Feb 19, 2021 | 01:31 PM
Pablo Chois
https://www.youtube.com/watch?v=fmsGdsZ2fpA
Thanks for your response. This is the process I'm following, both reset and learn give me the error I posted, which is why I don't know if it's a software issue, an issue with the cable, OR an issue with one of the modules in the car.
Old Feb 19, 2021 | 02:11 PM
Pablo Chois
Borrowed a Schwaben scanner from a friend, some people say it's the same as INPA. It's giving me an EWS code 1656, there is an option to service the EWS but it says the model doesn't support it. Has anyone seen this before?
Old Feb 26, 2021 | 07:32 AM
Pablo Chois
For those of you following, the issue was a bad EWS. Got a new one, programmed, starts right up.
Old Aug 10, 2021 | 02:15 PM
papidosxx's Avatar
papidosxx
hello!
I am having the exact same issue. Can you tell me where you bought the ews from?
Old Aug 12, 2021 | 12:40 PM
Pablo Chois
Originally Posted by papidosxx
hello!
I got it from the dealer. You can get a used one on ebay or AllMag (there are other sites that sell used EWS) but mine has a warranty on it so it was worth the extra money.
bearheroes
Electrical
18
Mar 27, 2016 06:22 AM
pawea
Jun 28, 2014 06:23 AM
wuttuptae
Dec 2, 2010 08:01 PM
3liter914-6
Mar 22, 2010 05:36 AM
matweekly
Jan 6, 2007 06:39 PM
