R50/53 Rally Light Wiring
Old Feb 6, 2021 | 02:51 PM
jjcsnlynn's Avatar
jjcsnlynn
Rally Light Wiring
I have what I believe are factory installed Rally Lights on my R53. They only work on high beams. I read in a thread here that that was correct.
I want them to come on with both high and low beams. Does anyone have a wiring diagram and know if any coding was required?
If I can figure out the wiring, I should just be able to move the relay activation wire from the high beams to the parking lights if no coding is required
Old Feb 6, 2021 | 03:35 PM
deepgrey's Avatar
deepgrey
Why would you ever want to run them with the low beams? It’s not safe to have them on with oncoming traffic.
Google is your friend. Driving light installation instructions.
There is no coding required.
Old Feb 6, 2021 | 04:35 PM
jjcsnlynn's Avatar
jjcsnlynn
Because I live in the country.
Thanks for the link. I searched on NAM.
Old Feb 6, 2021 | 05:51 PM
deepgrey's Avatar
deepgrey
I’m not sure why living in the country makes any difference, but whatever. IIRC, the wire you need is normally at the BCM, but don’t quote me on that. It’s been a while since I looked at the driving light setup.
Old Feb 9, 2021 | 11:38 AM
The old school MINI ads had the light on the hood and when you go out in the country you can do this. Old MINI ad.
Old Feb 9, 2021 | 12:24 PM
Capt_bj's Avatar
Capt_bj
GEN1 driving lights install is here: https://www.minimania.com/pdfile/NMA3030_INSTR.zip
Correct the trigger wire does connect at the BCM and if you move it elsewhere you can change how they work (but be aware that the 'reset' feature complicates matters to some degree)
this is not 'legal' but only a few states have checks where it will be a problem
Cockpitcreator
Jul 18, 2016 11:09 AM
1MCM
May 9, 2016 11:10 AM
packruler
Electrical
Mar 6, 2014 11:48 AM
Bullet2006
Jul 1, 2007 10:41 AM
