Are these the PoorMansUpgrade calipers?
Old Jan 29, 2021 | 04:55 PM
FakeName's Avatar
FakeName
Saw these in a local junkyard, I believe the car was marked as a 2007.
They’ve been slopped with red paint.
Are these the upgrade for my 03R53 or my 04R50? Both are on 17” wheels.
I realize they’d need a good cleaning and adapting front brake lines. Yes, rotors, too.
thanks.
Old Jan 29, 2021 | 10:39 PM
RB-MINI's Avatar
RB-MINI
My reply from the other thread.
Originally Posted by RB-MINI
No, those have the retaining clip/wire which were on regular 1st gen calipers. If the car was tagged correctly as an ‘07 it should have been a Cabrio.
For the poor man’s conversion you need 2nd gen calipers from an S. If not, you won’t have the larger 294mm rotors.
If any brake parts are listed as 2007 or 2008, you have to make sure they aren’t from a 1st gen R52 or R52S. Not sure about Countryman calipers, but the others probably are fine. I used Clubman S calipers for my conversion. To be sure if they’ll fit you should cross check the part numbers to between the 2nd gen models to expand the pool you can search from.
Old Jan 30, 2021 | 08:24 AM
FakeName's Avatar
FakeName
Thank you!
Did this get posted twice? It was not my intention, but I noticed a glitch in the posting process from my mobile device.
Racingguy04
46
Feb 21, 2021 07:41 PM
FakeName
Tires, Wheels, & Brakes
Jan 29, 2021 10:02 PM
rsbell
55
Jan 9, 2015 12:55 PM
scotwilson4403
May 29, 2013 06:12 PM
dustinhxc
Jun 12, 2008 08:18 AM
