r52 Horn not working
Old Jan 1, 2021 | 01:49 PM
Cobre's Avatar
Cobre
My r52 horn hasn't worked at all since I bought it used a few weeks ago. The person I bought it from told me that their mechanic had done some work on something (clutch IIRC), and hadn't hooked the horn up. I'm not sure where to start looking for the fix, and also haven't had a chance to check the fuses. Maybe I can look at them tomorrow.
Also it seems to me that my cruise control and volume controls don't work, so I'm assuming that they're related.
Any ideas?
Old Jan 2, 2021 | 10:20 PM
ssoliman's Avatar
ssoliman
Def check fuse first.
then I’d check for 12v at the horn plug.
Old Jan 3, 2021 | 03:43 AM
Capt_bj's Avatar
Capt_bj
sounds like all the buttons on the steering wheel are not working .....
that suggests more than the horn fuse
more like something of a multiconnector in the steering col' has come undone . . .
6 disconnected and the buttons don't work ....
Old Jan 3, 2021 | 06:27 AM
Cobre's Avatar
Cobre
yep, horn fuse looks fine. I guess I need to tear into it and check the harnesses.
Old Jan 3, 2021 | 07:12 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
When they replaced the clutch. Did they plug the horns backup. You can see by popping the hood.
Old Jan 3, 2021 | 10:53 AM
Eurothrasher's Avatar
Eurothrasher
Can see horns/wiring and connector thru these two openings......Prob not plugged in.
Old Jan 3, 2021 | 12:26 PM
Cobre's Avatar
Cobre
Thanks for the input. I just popped the hood, and I couldn't see anything wrong, but I'm not 100% sure what I'm looking for. It did look like there was a missing connection on one side, but I'm almost positive that it was for the light. I'm assuming the horn is below the light? Here are some pics:
Left side, looks like everything's connected
Right side, seems to be missing a connection?
Old Jan 3, 2021 | 02:26 PM
Eurothrasher
Old Jan 3, 2021 | 02:30 PM
Eurothrasher
For 2nd gen replacing horns was common.....not so for 1st gen. Mine are original......If memory serves the horns in 1st Gen are in series from pass side to dr side....if one side not connected I believe the other side will not work as well. Been a while since I've ever messed with them......
The socket circled is where the T10 bulb / socket for from marker ( parking ) light.....looks like they forgot to plug that in....
Old Jan 3, 2021 | 06:17 PM
Cobre's Avatar
Cobre
Looks like both horns are plugged in. As soon as I get a chance I’ll go and mess around with a multimeter. These are 12v, right?
Old Jan 3, 2021 | 08:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We see the Gen 1 horns fail pretty often so they could just be bad, but verify they are getting the signal first.
If you need them these are an affordable replacement option
https://www.waymotorworks.com/hella-...-horn-kit.html
Old Jun 3, 2024 | 03:21 AM
Haikojeem's Avatar
Haikojeem
Just stumbled upon this thread about a horn hitch on the R52. Bummer, right? It’s like having a lead foot but no gas in the tank!
Air horns, huh? Well, that's an ear-catching suggestion! I mean, who wouldn’t want their ride to blast out like a big rig on the highway? But seriously, getting your horn back in action is crucial – it’s your voice on the road, letting others know you’re there or giving a friendly toot to your neighbor.
As for me, I’d say fixing the stock horn would be priority numero uno. Gotta keep it classic, am I right? But hey, if you’re feeling adventurous and wanna turn heads (and maybe startle a few pigeons!), air horns could be a fun mod to consider. Just be sure not to scare Granny when you pick her up for bingo!
maytag
Aug 12, 2020 10:08 AM
Thumper Simpson
Sep 29, 2018 11:28 AM
thatminicarguy
Jul 18, 2017 12:47 PM
Jonathan66
Oct 17, 2014 10:53 AM
Theta
St. Louis MINI Club
Mar 6, 2012 12:48 AM
