Upgrade H/K Amp
Old Dec 16, 2020 | 12:30 PM
KindaCoolDad's Avatar
KindaCoolDad
Upgrade H/K Amp
I’ve seen plenty of threads on speaker upgrades and the many options available. I’m wondering if anyone has upgraded their HK amp to a better amp? Are there even options out there to do that?
Old Dec 18, 2020 | 01:35 PM
James297's Avatar
James297
I’m upgrading to a Audison AP F8.9 which is going to be great. Audison also sell an AP 8.9 which with the right harness is plug and play!
Old Dec 23, 2020 | 08:35 AM
6FT6's Avatar
6FT6
Do you have any more info on this? This may the solution I am looking for.
Old Dec 23, 2020 | 10:28 AM
KindaCoolDad
So far I’ve found that BimmerTech and Audison are the two that offer plug-and-play amplifiers. I ordered the one from BimmerTech and will follow up with the results.
I do like the sound of Audison offerings, but finding dealers locally was tough.
Old Dec 23, 2020 | 11:23 AM
James297's Avatar
James297
Try www.audison.eu there will be a page where you can find your nearest stockist👍
I have installed mine and I now have a 3 way active front and an active subwoofer and my system sounds amazing 🤩
Old Jan 16, 2021 | 01:21 AM
KindaCoolDad
I ended up going with the BimmerTech amp. Come to find out I'm the first person to buy one for the F60 series, because the first bracket that came with the amp didn't fit the stock amp area. They sent out another bracket and now it fits
perfectly. Also worked with them to tune it to my choice, and it's nice to have access to the software for further customization. Thanks to the amp placement, I'm able to leave the USB cable plugged in and just hidden behind a panel I can access at any time.
It was definitely worth the upgrade! It makes the OEM speakers really shine.
Old Jan 17, 2021 | 05:35 AM
NBCGLX's Avatar
NBCGLX
So you upgraded the h/k amp to this, but left the h/k speakers? Interesting, as it seems most OE stereos seem to have the speakers as weak points.
Old Jan 17, 2021 | 07:24 AM
KindaCoolDad
That’s not always the case. In some factory setups, the amp is the weakest link. Over time, I may upgrade the speakers. But I felt it was better to start by improving the power delivery to the speakers rather than putting improved speakers on a subpar amp.
The HK speakers sound much cleaner and stronger now. What’s more, I can fully customize the EQ settings of the amp to tailor the sound to my preference.
Old Jan 17, 2021 | 09:16 AM
NBCGLX's Avatar
NBCGLX
Nice, and glad you’re happy with the upgrade!
Old May 8, 2021 | 12:08 AM
tsaylor's Avatar
tsaylor
I'm considering this as well, so I'm curious how this is working out for others. @KindaCoolDad, I noticed you were selling a full system so I'm assuming you ended up adding the speakers as well. Curious how much each piece of that upgrade added to the system, and any additional impressions you may have. I'm coming from a prior vehicle which had a large amp and also a 10" subwoofer (aftermarket), so I'm really missing that punch. The HK system does already sound better than most factory systems, but when I turn it up a bit it seems like something is missing. I've heard it said that BMW does some equalization adjustments which actually limit that power, sort of a governor of sorts, preventing the fairly common problem of blown speakers.
As an aside: I'm tempted to re-use that subwoofer now, and I've read that the bimmertech amp even supports an additional sub. That sub is in a fairly large box -- I'd really like to fit it in the lower rear storage section instead. It's been recommended that I should keep that sub box for the best sound, but I hate to take up so much usable space with it.
Old May 8, 2021 | 02:36 AM
KindaCoolDad
The overall system is much cleaner and sharper across all volume levels. That was my biggest issue with the HK, I had to turn it up 3/4 when driving to hear it well, but the sound wasn’t clean.
Working with BimmerTech was super. Once I installed all the speakers, I did a phone call and they remoted into my laptop and we tweaked the sound based on my tastes.
The new system, like the HK, does not give you hard low bass. But the mid bass is much more pronounced, and I rarely turn it up halfway now. It’s silly expensive, and yes, a knowledgeable person could likely do more and better for cheaper. But this is worth every penny to me since it was 100% plug and play, and the remote support was solid.
Old May 8, 2021 | 08:53 AM
tsaylor's Avatar
tsaylor
Thanks a lot for those details! It does seem like I'll need at least the amp upgrade. Were you able to tell, how much of the improvement came from the amp, and how much from the speakers? I'm assuming the bass may still not be enough for me even with the full upgrade, but it sounds like a very significant improvement in any case.
Old May 8, 2021 | 09:51 AM
F56-JCDub's Avatar
F56-JCDub
I found on my old F60 the HK speakers seemed muddy. When I upgraded to the Bavsound speakers, everything was clearer, at all levels, but I also recall that the system would have been even better with an amplifier. They didn't have an amplifier but my research sent me in the same direction as above with Audiotech Fischer. Unfortunately at that time (2+ yrs ago now), they only had "profiles" that could be customized and uploaded, they didn't allow you to do your own customization in the DSP. It seems like you can do that now if I'm interpreting what's said above correctly.
If I were to do it over again, I wouldn't upgrade the speakers just yet, I'd go amp first, then speakers. Or amp and speakers at the same time.
Old May 8, 2021 | 10:53 AM
F56-JCDub's Avatar
F56-JCDub
Also, I just remembered, that there appear to be three "plug-and-play" versions of this amp upgrade which are all made by Audiotech Fischer. After digging around It's all coming back to me:
1.) BimmerTech's amp PP86DSP AMP/DSP: 8-channel
https://www.bimmer-tech.net/speakers...ifier-for-bmw/
2.) Audiotech Fischer
MATCH PP 86DSP: 6-channel
https://www.audiotec-fischer.de/en/m...fiers/pp-86dsp
3.) Audiotech Fischer MATCH UP 7DSP: 7-channel
https://www.audiotec-fischer.de/en/m...ifiers/up-7dsp.
4.) Bavsound used to offer another Audiotech Fischer clone called the "REVENANT" but no longer offer it for MINI.
Old May 9, 2021 | 11:58 PM
KindaCoolDad
I did the amp first, then the speakers.
The amp with the HK speakers: louder and stronger but not clean. We tried many different tunes (at least 8), but it was flat with the highs and/or muddy with the bass. If we could do a tune in the shop, it might've worked, but we couldn't find a sound that fit.
Old Oct 28, 2021 | 10:44 AM
Mand0o's Avatar
Mand0o
Were you able to find a tune that you were happy with or are you deciding on upgrading the speakers?
Old Oct 28, 2021 | 04:40 PM
isugoo's Avatar
isugoo
you can swap HK amp to Match UP 7BMW. it's direct swap. No need to have a power/ground wire running through battery to trunk. If you want something simple, this is good choice.
I upgraded my HK to: Match UP 7BMW, Focal K2 front components, Bavsound center/rear/subwoofers. It's not the best but pretty good for money.
If I re-do, I will prob. get Match UP 7 BMW and all Bavsound. easier/cheaper option for decent sound.
konacoug
Nov 4, 2019 04:26 PM
JeffHarper
Apr 7, 2013 12:18 AM
Winkley
Jul 27, 2008 05:11 AM
