R55 2011 Clubman R55/N18 No heat?
Old Dec 6, 2020 | 11:08 AM
unclemiltie's Avatar
unclemiltie
Now that it's gotten cold again I'm getting no or very little heat in the passenger compartment. No check engine light so I'm assuming that the cooling system is getting to temperature properly. Engine runs good.
Every now and then I'll get a bit of warmth out of the dash, but nothing like it should be.
Earlier this year I replaced the thermostat housing that was leaking, don't know if that would be part of the issue. I did have to use a wire adapter to adapt the newer version of the housing to the existing harness. But that was pretty straightforward.
Suggestions on where to look? I have a Autel Bluetooth diagnostic tool if that'll help hunt things down.
Old Dec 6, 2020 | 12:48 PM
unclemiltie
More information
I fired up the Autel and checked some things out.
  • As I suspected the engine temperature is right where it should be, sitting about 80C when the car is warmed up
  • There is a reading for the "heat exchanger" which sounds like it might be the heater core. That is at 7-8C while the engine is at 80.
So for some reason the hot is not getting into the cabin but the engine is making plenty of it.
Old Dec 6, 2020 | 01:35 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Are you sure you got all the air out of the heater core when you replaced the thermostat?
Old Dec 6, 2020 | 01:38 PM
unclemiltie
"Sure"? no, but I did get liquid squirting out of the bleed hole when I did that part. I should probably check that again though.
It's so fun trying to find that damned thing! I'll pull the car into the garage tomorrow and give it a try. any hints on what I might have missed when I did it back in June?
Old Dec 7, 2020 | 03:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
All I know is you need to make sure the heat is on high to get the heater valve to open, then a start the car to get the water pump spinning.
When I replaced my thermostat, I used a vacuum tool to suck the coolant into the system.
Old Dec 7, 2020 | 04:56 AM
Jason Cornelius's Avatar
Jason Cornelius
Can’t you also you the motive bleeder and do it that way? I think I’ve seen coolant flushes done using it, I’ll post YouTube links when I run across them again.
Old Dec 7, 2020 | 08:31 AM
crazy4trains's Avatar
crazy4trains
You say the car is a 80C when warm. That sounds about 20-25 degrees low. Mine runs around 102+/- degrees C when warm. Unlock your display on the tach and monitor it.
Old Dec 7, 2020 | 09:50 AM
unclemiltie
it may not have been fully warm, I was just sitting in the driveway.
I did get some "air" out of the vent hole and the coolant reservoir went down about 1/4 of the capacity when I vented the air. hopefully that was my issue, I'll be driving the car later today and will check. (and will put the Autel on it to monitor the temp, but just for grins how do I unlock the display to get stuff like temp? And what else can I see when unlocked?)
I know that I did the vent when I installed the thermostat since I could see the dried coolant around the vent from when the liquid came out. maybe I should have done it twice.
Old Dec 7, 2020 | 10:15 AM
crazy4trains
Just go into YouTube and search "unlock hidden menu mini cooper r56". Many videos showing you the process. Once unlocked go to test number 7.
Old Dec 7, 2020 | 10:17 AM
Jason Cornelius
Old Dec 8, 2020 | 04:58 PM
unclemiltie
I drove it for a while today and yesterday and the warmest I saw it was 103 when I was getting off the highway and then in the high 80's/low 90's when driving around town.
The good news is that I have heat in the car, so that small amount of air must have been my problem. I had to add about a cup of coolant so it wasn't that much, but the heat works great now!
thanks all!
Old Dec 8, 2020 | 05:23 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Glad you got it settled without too much extra work
Jerry661
Nov 17, 2019 09:51 AM
MiniToBe
Sep 19, 2019 09:57 AM
dube53
Mar 24, 2016 02:47 PM
boiseminis
R55 :: Clubman Talk (2008+)
Oct 1, 2014 10:19 AM
laptop87
Aug 15, 2014 06:50 AM
