R52 Converting an S to a Base
Old Nov 9, 2020 | 01:51 PM
JohnMcF's Avatar
JohnMcF
OK, weird question. I'm into SCCA club racing. Have the opportunity to get an S model chassis that will be parted out by a friend of mine. Now the class I want to run will require a base model setup for the engine. My question is in regards to the engine management system/harness and ECU. Being an S model I know the wiring is set up for the forced induction. I can swap in a R50 intake simple enough. Would I need to swap out the entire wiring system?
Comments?
Old Nov 10, 2020 | 07:32 AM
JohnMcF's Avatar
JohnMcF
Anyone? I'm hearing crickets!
Old Nov 10, 2020 | 07:44 PM
Minifenrir's Avatar
Minifenrir
Be cheaper to just buy a base model Mini.
Old Nov 12, 2020 | 01:46 PM
JohnMcF's Avatar
JohnMcF
I've been searching for that next to nothing $$ base donor car.
Old Nov 12, 2020 | 04:07 PM
OCR's Avatar
OCR
Sure...the ECM would need to know that the blower / pressure is gone..! Everything to do with the blower would be gone.
The entire ECM mapping would be different, the ECM would need to understand why there is no pressure in the system.
If you swap ECM's, any wiring related to the blower / pressure / pop-off valve, etc., can just hang there as long as an R50 ECM is used.
You would need to raise the compression ratio if an R53 engine is used...right ?
Mike
JohnMcF
Nov 12, 2020 01:33 PM
madmix
Navigation and Audio
Jun 29, 2020 09:41 AM
g34343greg
Sep 30, 2014 07:09 AM
jaydub
May 26, 2010 01:15 PM
