R50/53 Window Regulator Pop
Old Oct 20, 2020 | 06:08 PM
Mini Wrench's Avatar
Mini Wrench
Window Regulator on the passenger side cable broke Ordered an aftermarket window regulator and installed it, now i get a pop when it goes up. I can't figure it out, i made no adjustments' of any kind. Window goes up and down fine except for the pop? watched alot of you tubes, no help. Any help would be appreciated.
Regards
Old Oct 20, 2020 | 06:29 PM
ssoliman's Avatar
ssoliman
does it make the pop with the window out? if it does its probably the regulator
if it pops is with the window in (but not out) it might be the window hitting the cables. make sure the cables are in the clips and the clips are closed
one of mine makes a click also. its the design of the regulator, slack in the cables...
Aftermarket regulator or oem?
Old Oct 20, 2020 | 08:10 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I have aftermarket on both sides of my 04 R50. They work great.
Old Oct 20, 2020 | 09:15 PM
Mini Wrench
I am glad yours works great. Mine does not. Can you help me fix mine?
Regards
Old Oct 21, 2020 | 06:15 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Did you secure the cables back to the correct spots?
Old Oct 21, 2020 | 08:21 AM
Mini Wrench
All cables are back in there original spots except for the two at the very top, the barbs are broken off.
Regards
Old Oct 21, 2020 | 08:23 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Thats where I'm sure you are getting the pop from. You should have extra from old regulator.
Old Oct 21, 2020 | 08:29 AM
Mini Wrench
I will check it out and get back. Those two are missing or broke.
Regards
Old Oct 21, 2020 | 05:05 PM
ssoliman's Avatar
ssoliman
you can purchase the repair kit, OEM part, comes with two clips and other stuff for like 25$
Old Oct 23, 2020 | 07:47 AM
MINI_42's Avatar
MINI_42
I also get a loud pop when my window goes up. Subscribing for future reference when I get to looking at it.
Old Oct 26, 2020 | 01:25 PM
alconk's Avatar
alconk
Yes if those top white clips aren’t secure it will make that noise you’re describing
Old Nov 7, 2020 | 03:23 PM
Mini Wrench
I replaced the window regulator with anther new one and it still pops when it is all the way up at the top, also when the door is opened and then closed it goes down then up like it supposed to then pops. I will check the white clips again but when they where put in i put them in correctly. I am at a loss after two regulators and still pops.
Regards
Old Nov 7, 2020 | 07:24 PM
ssoliman's Avatar
ssoliman
Does it come threw on video?
pop sound coming from inside the door or up at the top of the window?
im at a lost. How can a new regulator pop
Old Nov 7, 2020 | 07:36 PM
ghostwrench's Avatar
ghostwrench
Does it pop when operating the window with the door open as well as when the door is closed?
Old Nov 7, 2020 | 08:25 PM
Mini Wrench
The loud pop does it with the door is open as well with the door closed, when it pops you can see the cables inside the door jump as well. It only pops when the window is all the way up.
Regards
Old Nov 8, 2020 | 03:45 PM
jk6672's Avatar
jk6672
Start by troubleshooting. If you installed to cover, take it off and see if you can pinpoint where the popping is coming from by listening for the pop while the window is moving.
Old Nov 8, 2020 | 05:51 PM
ssoliman's Avatar
ssoliman
New regulator or used? Oem?
Old Nov 9, 2020 | 06:24 AM
Mineeee's Avatar
Mineeee
Mine started to do the same thing,an alarmingly loud pop right as the window reaches the top of its travel, door open or closed.
My cable retention clips are also toast so I'm thinking thats a likely cause, but I haven't taken it apart to check yet.
Keep us posted.
Old Nov 9, 2020 | 06:49 AM
MVPeters's Avatar
MVPeters
I'm not sure if this helps, but if you haven't done it, give it a shot.
Reset the window limits - press the window switch down & hold it for 30 seconds, then up & hold for 30 seconds.
See if it makes any difference!
Old Nov 10, 2020 | 09:38 PM
Mini Wrench
I have installed two new aftermarket ones from eBay both do the same thing.
Regards
Old Nov 11, 2020 | 06:54 AM
Mineeee's Avatar
Mineeee
Didnt help mine, but thanks for the suggestion.
Old Nov 11, 2020 | 02:32 PM
ssoliman's Avatar
ssoliman
If it clicks after the window lands, is the cables, slack in the cables. It’s the regulator itself that is “broken”
There’s a spring on the cables, you know the one? It should be compressed to take up slack in the cables...keeps it all together and quite...
I’m not sure I am helping you
Old Nov 11, 2020 | 09:33 PM
mr.r50's Avatar
mr.r50
Regards
i have the same problem, you need to align the window when it’s up and closing the door, follow the pelican walk thru, or it will stay popping
Old Nov 11, 2020 | 09:35 PM
mr.r50's Avatar
mr.r50
Fig #37 and #38 https://www.pelicanparts.com/techart...eplacement.htm
Old Nov 12, 2020 | 11:15 PM
jk6672's Avatar
jk6672
Keep us posted.
That’s gotta be it. I replaced my passenger side today and the two white retaining clips were broken away from the door. And it popped when I assisted the window up with the old regulator.
traildog
Apr 6, 2015 10:41 AM
calliemini
Jan 17, 2013 12:03 PM
6String
Feb 23, 2005 03:05 PM
OutMotoring
Feb 22, 2005 08:37 PM
LizzyBobio
12
May 18, 2003 07:43 AM
