R50/53 Compression check done...
Old Oct 12, 2020 | 05:45 AM
steve05ram360's Avatar
steve05ram360
Numbers dont look good... averages of 3 tests...
#1 145
#2 98
#3 115
#4 115
Sure does not drive like it has a hurt motor.... still running the oil that was in it from the day it was bought, PO said it was just changed. A swap has been on the todo list for this week. Planning to run a 10W-30 oil, once that is done, will re-check it but not expecting any change in the numbers
edit: will do a leakdown test to determine where its bleeding from...
Old Oct 12, 2020 | 08:09 AM
MVPeters's Avatar
MVPeters
I agree those numbers are not reassuring, but I suspect the test was done with the throttle closed.
Please try again, all 4 plugs out, throttle wide open, 6 or 7 cranks to pump the gauge up. 150 lbs psi +/- 10% is a good target.
Old Oct 12, 2020 | 09:03 AM
steve05ram360
Throttle open?? no, throttle was in the NC position... Does not explain that 145 psi #1 cylinder, which repeated at the end of the test. Pulled the #1 plug again to double check and it came back with the same pressure. I will see if I can get this done at lunch and report back...
Is there a fuse for the fuel pump that I can pull?
Old Oct 12, 2020 | 09:57 AM
MVPeters's Avatar
MVPeters
Yes, there's a fuse & yes, you could disconnect the coil pack but there's no real need to do either.
All four plugs out & throttle wide open will simply give a more accurate set of readings.
A leakdown would be well worthwhile. Take your time!
Old Oct 12, 2020 | 10:15 AM
steve05ram360
the motivation behind the fuel pump fuse is to not dump fuel into the cylinders... no pressure, next to zero fuel. I did have the coil disconnected and had fuel on the compression tester end.
Old Oct 12, 2020 | 10:36 AM
MVPeters's Avatar
MVPeters
Yes, that's fine! You could also squirt a little oil into the cylinders to seal the rings.
But a leakdown test will really show where the problem is.
Since you haven't had the car all that long & it seems it's running basically 'OK', I'd put a very generous dose of carb cleaner in the tank. With any luck, it might just be gummed-up valves.
Old Oct 12, 2020 | 10:56 AM
steve05ram360
Yeah I thought of the wet test as well, the leak down I will do if the wet test returns odd results. It is very odd though to have 1 cylinder high while the others low. If the re-test gives say 145 avg across all cylinders then that makes me think there might be an issue with the #1 cylinder where it always read high while the others did not with the throttle closed. That would make me think its got a free flow of air to build pressure like that. Additionally, #1 & 2 being side by side, the #2 was the lowest measured... hummm... love finding problems!
Old Oct 12, 2020 | 03:06 PM
steve05ram360
Pulled F2 for the coil & injectors then did comp check on a "warm" motor (>170*)...150,100,130, 122...
and now no-start, no codes.
Old Oct 12, 2020 | 03:50 PM
steve05ram360
Fixed... battery disconnect for >20 minutes, re-connect, start motor, stop motor, clear codes and golden.
Old Oct 12, 2020 | 05:39 PM
steve05ram360
Did an oil change today after getting it back on the road... switched to Royal Purple 10w-30. Have no idea what was in there before. Will re-check compression after 500~1000 miles to see if there is a change. Research says it is possible there could be a stuck ring with carbon buildup. If that is the case I wonder if the seafoam thru the intake would be able to free that. The leakdown test should tell the tale though.
Old Oct 12, 2020 | 06:37 PM
MVPeters's Avatar
MVPeters
If you think it's rings, I'd put Seafoam direct into the cylinders & let it soak overnight. More likely is a sticky valve, which Seafoam should help with.
Old Oct 12, 2020 | 06:46 PM
steve05ram360
You mean carbon on the valve seat? I think the sea foam fog would fix that. What I will do is add an access hose off the FPR when I wrap the fuel line. Also with the oil change today and the additional BPV bandaid spring, thing is noticeably quicker with boost response. Still need to swap the BPV.
Edit: Yeah, rings...
Old Mar 9, 2021 | 06:15 PM
steve05ram360
Update... compression test done, 137k (?)
#1 153
#2 110
#3 120
#4 135
Sure does not run like its got a hurt motor... running significantly better than it had been.
Still need to do the leakdown test.
Old Mar 18, 2021 | 10:14 AM
steve05ram360
Another full can of seafoam processed thru the engine... still lots of smoke @ the exhaust. Engine started easier this morning.
Will be doing compression test again in the next day or so
03.BRG.MCS
Sep 20, 2013 07:01 PM
jamez
Oct 4, 2012 09:04 AM
eric loe
32
May 11, 2010 11:19 PM
joecooper
Nov 23, 2006 10:09 AM
tacotim
May 4, 2003 01:09 PM
