R60 Turbo spooling right after start up
Old Oct 8, 2020 | 05:41 PM
7rhSon's Avatar
7rhSon
2012 Countyman 2wd 109k
So back in March i had my HPFP replaced under warranty, and they also did the footwell module.. when I got it back I noticed upon start up my turbo kicks on a spools.. any thoughts or help? I'm thinking I could try to get it replaced under warranty. My shop does plenty of business this motor group that's affiliated with this dealership..
Old Oct 14, 2020 | 03:52 AM
jawilli6's Avatar
jawilli6
I don't have a lot of experience with turbos, but I see you don't have a response.
I don't see how your turbo could be spooling up without the engine idling faster. Engine RPMs increase pushing more gasses into the exhaust which in turn spins the turbo faster. Without higher engine speed, the turbo can't spool up. I guess maybe if there was a serious restriction in the exahust pipe such that more gasses were directed towards the turbo.
Or perhaps you hear air coming from it, like the wastegate is stuck open?
Hopefully someone more knowledgeable will tune in. I know at one point I attempted to find the turbo boost pressure data with the Schwaben scan tool, couldn't find it. If that's data that can be found maybe you could read it and compare to some benchmark value.
Old Nov 8, 2020 | 06:31 PM
CountryMouse's Avatar
CountryMouse
What is making you think the turbo is spooling up when starting it. The turbo is always spinning while the engine is running and can't spool faster than the exhaust gasses allow.
BubbaJCW
Factory JCW Talk (2009+)
Dec 22, 2021 04:42 PM
gimmea250swb
Apr 9, 2018 05:41 PM
vaselas13
R60/R61 Stock Problems/Issues
Jul 17, 2014 12:38 PM
myfirstcooper09
May 17, 2014 02:12 AM
r56mini
Nov 19, 2007 04:48 PM
