Suspension For those of you with spring noises
Old Dec 28, 2004 | 09:33 AM
meb's Avatar
meb
I happened to have some time today and was reading a number of posts regarding dampers and springs. A number of us have complained about spring noises. I'll offer a fix for spring slap that has worked for me every time - and I apologize if this has been posted, but I could not find a related subject.
Simply go to Radio Shack or some other electronic store and purchase coiled wire wrap. This wire wrap is meant to house all those loose wires behind your TV chest or Amoire. It turns out to work quite well as a wrap for springs too. This product is a bit tedious to install, but well worth the effort, especially with progressive rate springs. High density plastic, used for irrigation piping among other things, also works well in spring perches. If you obtain this product in 1/16" or 3/32" thickness, you'll have little if any problems re-adjusting ride hieght. This plastic is also black. This, for those of you with Aluminum spring perches.
Just a random response. Hope the above helps some of you.
Old Dec 28, 2004 | 03:52 PM
kenchan's Avatar
kenchan
You will want to install this wrap on every other spring where the coils are
close together. The coils hit each other and make the chattering noise
over bumps. (sounds like metal against metal).
Old Dec 29, 2004 | 09:05 AM
meb's Avatar
meb
Actually, just wrap the entire coil, this will not affect how they work. Wrapping every other coil leaves room for the wrap to move a bit - depending upon the spring.
Old Dec 29, 2004 | 11:11 PM
minie's Avatar
minie
so how much in total would i need to wrap all 4 spring?
Old Dec 30, 2004 | 08:03 AM
kenchan's Avatar
kenchan
You just need to wrap it snug (pull while you wrap) and it
won't move. You can even e-tape it if you're worried.
I don't like to add extra wrap between the springs where it will
affect travel and spring rate, but that's just me.:smile:
btw, one package is more than enough.
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Sep 10, 2015 12:06 PM
Sep 8, 2015 11:37 AM
Sep 3, 2015 02:06 PM
