Problems with the new turbo
Old Sep 26, 2020 | 12:07 PM
Michaelh57's Avatar
Michaelh57
I recently blew my turbo and had a new one installed that was supposed to be the exact same. My question is that the car no longer wheel spins when using sport mode. I have an RPM stage 2 tune that I had mapped to sport mode and I always had wheel spin with my old turbo but none with this one. Do new turbos have a break in period or something along those lines? I’ve drove probably less then 100 miles since the new turbo was installed.
The car also sometimes when boosting sounds like it gets stuck. I’m not sure how to describe it other then that. Instead of the smooth sound as it is accelerating it sounds like a broken record repeating the same sound and letting off the accelerator fixes it. All the connecting hoses that go with the turbo were changed at the same time as well.
Old Sep 26, 2020 | 02:18 PM
Michaelh57's Avatar
Michaelh57
So I got a boost gauge and I’m making 18 lbs of boost. Could it have been previously over boosting from the faulty turbo.
Old Sep 27, 2020 | 02:11 AM
Jason Cornelius's Avatar
Jason Cornelius
If I’m not mistaken rpm stage 2 tune you should be seeing around 20 psi, you might have a small boost leak somewhere.
Old Sep 27, 2020 | 04:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Is the “new” turbo remanufactured or an eBay turbo? If it’s a cheap replacement, could be that the new one is faulty... There shouldn’t be a break in period with a new turbo.
Old Sep 27, 2020 | 07:39 AM
Michaelh57's Avatar
Michaelh57
So after driving some more it is hitting 20 but the turbo is name brand borshwargner or however you spell it
Old Sep 29, 2020 | 07:38 AM
mikey_t's Avatar
mikey_t
"borshwargner " ??? Do you mean your mechanic installed a Bosch Wagner turbo kit?
Old Sep 29, 2020 | 07:50 AM
2012_R60's Avatar
2012_R60
RPM tune usually has boost by gear meaning it doesn’t call for full boost on every gear so you optimize traction. Pretune the ecu calls for full boost at WOT no matter what gear you’re at. That’s probably why you don’t wheel spin as easily. Check with your tuner to make sure.
Old Sep 29, 2020 | 11:54 AM
Michaelh57's Avatar
Michaelh57
Yes sorry I didn’t feel like checking on the spelling but yeah that’s the one. And it has the same tune as it did before literally the only thing that has changed is the turbo itself. But the car has been hitting 22 psi in sport mode so I’m keeping it out and having it reflashed back to stock.
Old Sep 29, 2020 | 01:56 PM
Jason Cornelius
Man I’m pretty sure you are good on the tune and those are the right numbers. Reach out to Mario kart here on NAM. He is the man when it comes to RPM tunes.
Old Sep 29, 2020 | 03:36 PM
Michaelh57's Avatar
Michaelh57
Well would there be another reason for blowing turbos? Because my mechanic thinks the brand new one we did friday is blown already
Michaelh57
R60/61 Cooper S Drivetrain
Sep 26, 2020 12:46 PM
cstrumol
Dec 11, 2019 01:11 PM
Baker856
Aug 3, 2016 07:05 AM
Indimanic
Oct 10, 2014 02:39 PM
shadyyu
R55 :: Clubman Talk (2008+)
Oct 5, 2009 02:18 PM
