R56 code scanner that can read each wheel speed sensor?
Old Sep 8, 2020 | 03:37 PM
Gabe3's Avatar
Gabe3
my abs light is randomly coming on. I think one of the sensors is going bad. theres a sensor in each wheel hub. apparently some scanners can view the speed from each wheel and that would tell me which sensor is bad. does anyone know if this would work?
Amazon Amazon
it says abs diagnostic functions. it should show a fault code, but would that fault code tell me which wheel?
Old Sep 8, 2020 | 04:42 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If the ABS light is coming on, I would expect there to be a code stored to tell you what is wrong. I would get either the Schwaben tool from ECS, or pick it up direct from Foxwell.
Old Sep 8, 2020 | 08:28 PM
Gabe3's Avatar
Gabe3
sadly my cheap bluetooth reader doesn't show anything. it usually works.
Old Sep 14, 2020 | 08:22 AM
I use my schwaben tool and it tells me which side and corner is at fault.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Old Sep 15, 2020 | 01:46 PM
thefarside's Avatar
thefarside
Hey ECS,
Will the Schwaben tool read the requested and actual camshaft angles? I've looked at the "poop" sheet for the tool and it is not clear. I have a 2013 MCS
Thanks,
Peter
Jwp2
Jul 22, 2019 10:42 AM
jeeporvis97
Dec 25, 2018 07:07 PM
xxxyank
May 30, 2018 07:28 PM
Ramiel
Feb 20, 2018 02:21 PM
K3nMasterS
Mar 11, 2015 07:09 AM
