my abs light is randomly coming on. I think one of the sensors is going bad. theres a sensor in each wheel hub. apparently some scanners can view the speed from each wheel and that would tell me which sensor is bad. does anyone know if this would work?
it says abs diagnostic functions. it should show a fault code, but would that fault code tell me which wheel?
njaremka
Alliance Member
close
- Join DateJul 2016
- LocationWNY
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:2,468 Times in 1,923 Posts
If the ABS light is coming on, I would expect there to be a code stored to tell you what is wrong. I would get either the Schwaben tool from ECS, or pick it up direct from Foxwell.
Quote:
sadly my cheap bluetooth reader doesn't show anything. it usually works.Originally Posted by njaremka
close
- Join DateJan 2013
- LocationWadsworth, Ohio
Liked:2,537 Times in 2,245 Posts
I use my schwaben tool and it tells me which side and corner is at fault.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Hey ECS,
Will the Schwaben tool read the requested and actual camshaft angles? I've looked at the "poop" sheet for the tool and it is not clear. I have a 2013 MCS
Thanks,
Peter
Thanks,
Peter
