F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Camber plates
Old Aug 27, 2020 | 09:54 PM
RazorRamon's Avatar
RazorRamon
Camber plates
Bought these wheels and test fit them recently.
They seemed to be a really tight fit. Was wondering if anyone here has experience with camber plates on our car. The only option that I could find was kmac camber kits. Given kmac doesn't seem to have good reviews, I'm kinda weary of putting them on. I also called up vorshlag since they are developing a kit for the F56 and they ensure me the kit will also fit the F54. Can anyone confirm? F56 and F54 uses the same top mounts?
Old May 18, 2023 | 06:43 PM
Marc124444's Avatar
Marc124444
Also looking, even Lohen in uk don’t have them for the electronically controlled dampers :(
Old May 19, 2023 | 12:05 PM
F54 and F60 are shared OEM parts on the plates. Not F56/F55/F57. Both NON EDC and EDC. If they did they usually shared the same part numbers to reduce cost.
The main difference in EDC or DDC (called the same thing) is the PIN size of the Shock, I believe its M12 and M10 or M14 from M12. Its like one step up for the larger pin for the wires. Everything else is pretty much the same.
The Suspension design of the F54 and F60 are very close the 2 series Active Tourer as the share the same UKL design platform.
Also BMW group had some issues with the stock plates so the superseded a couple times on the F56 platform.
https://www.northamericanmotoring.co...-failures.html
The plate might be the same size but i think the bearings or something is different like the bearing for more weight or All4 platform. No one i know has confirmed.
KMAC has these: https://www.ecstuning.com/Mini-2018-...n/Camber_Kits/
Bster13
Suspension
65
Dec 22, 2023 02:11 PM
holyspiritf56
Dec 21, 2019 04:25 AM
al the mini man
Jun 18, 2018 04:02 AM
#pepper#
Suspension
12
Mar 27, 2017 12:32 PM
auscoops
Suspension
29
Sep 7, 2008 06:54 PM
