F54 Camber plates
Camber plates
Bought these wheels and test fit them recently.
They seemed to be a really tight fit. Was wondering if anyone here has experience with camber plates on our car. The only option that I could find was kmac camber kits. Given kmac doesn't seem to have good reviews, I'm kinda weary of putting them on. I also called up vorshlag since they are developing a kit for the F56 and they ensure me the kit will also fit the F54. Can anyone confirm? F56 and F54 uses the same top mounts?
F54 and F60 are shared OEM parts on the plates. Not F56/F55/F57. Both NON EDC and EDC. If they did they usually shared the same part numbers to reduce cost.
The main difference in EDC or DDC (called the same thing) is the PIN size of the Shock, I believe its M12 and M10 or M14 from M12. Its like one step up for the larger pin for the wires. Everything else is pretty much the same.
The Suspension design of the F54 and F60 are very close the 2 series Active Tourer as the share the same UKL design platform.
Also BMW group had some issues with the stock plates so the superseded a couple times on the F56 platform.
https://www.northamericanmotoring.co...-failures.html
The plate might be the same size but i think the bearings or something is different like the bearing for more weight or All4 platform. No one i know has confirmed.
KMAC has these: https://www.ecstuning.com/Mini-2018-...n/Camber_Kits/
Bster13
Suspension
65
Dec 22, 2023 02:11 PM
