R50/53 New crankshaft pulley / harmonic dampener?
Old Aug 27, 2020 | 03:26 PM
dayman's Avatar
dayman
I just replaced the serpentine belt as it was fraying on my '05 R53 at 151,000 miles. While I was inspecting the pulleys I noticed that one of the previous owners had put an Alta 0% crankshaft pulley on there, and the old belt seemed slightly less wide than the new OEM belt that I ordered (maybe this was just from the general wear of the belt?). I had no idea at purchase that it even had that aftermarket pulley on there, even with a mechanics inspection only until I starting really looking at it. At some point I'd like to change out that Alta pulley and was wondering if I should just get a stock harmonic balancer or the ATI Super Damper instead.
ATI Damper
OEM Balancer
Any suggestions on replacing that crankshaft pulley, or should I just let it be?
Old Aug 27, 2020 | 04:41 PM
Mini Devil's Avatar
Mini Devil
ATI Damper
OEM Balancer
Its widely suggested to stay away from the light weight units. They cause premature bearing wear. You can find pics of it online with a quick search.
A lot of people have had good results with the PRW fluid dampened units. They're a good option if your looking to save some coin.
https://www.waymotorworks.com/fluid-...ulley-r53.html
The ATI units are supposed to be awesome. Keep in mind the standard drive pulley is .8% bigger than stock.
https://www.waymotorworks.com/super-...ulley-r53.html
For the money, I'd go ATI over stock. Its lighter and slightly cheaper
Old Aug 27, 2020 | 10:03 PM
dayman's Avatar
dayman
I'm not sure how long that Alta pulley has been on there for... In terms of wear, do you know what specifically in the engine would end up worn down?
Also do you think I should get this replaced ASAP with an actual harmonic balancer?
Old Aug 28, 2020 | 05:05 AM
Mini Devil's Avatar
Mini Devil
I would definitely get it out of there. Here's a link to another thread with some good info on the topic
https://www.northamericanmotoring.co...nk-pulley.html
Old Aug 28, 2020 | 09:56 AM
mr.r50's Avatar
mr.r50
I have a ati on my w11 motor right now, i def can feel a difference in it, vs the stock one,(weight wise) it came with my motor so i can’t say much vs it compared to a stock w11 motor , but on a w10 and w11 is a major power difference and to be honest i have no idea who and when to rebuild
Def wasn’t new one i got it, came with the motor i bought
it
Old Aug 28, 2020 | 11:43 AM
Derek86's Avatar
Derek86
When mine failed I did my research and the ATI damper was the way to go for me. Good quality part from a big company that backs their product, and an upgrade over stock in every way. I put on the 2% oversize version because more power baby.
The Alta pulley only exists because the stock ones have a high failure rate and the ATI units aren't cheap. They fill a hole in the market for budget replacements, but I think it is an inferior option.
Old Aug 28, 2020 | 12:51 PM
RB-MINI's Avatar
RB-MINI
it
Not sure on the inspection and rebuild interval as the recommendation on their site was unclear, and I never contacted them to get a definite answer. It’s either 5 years for a 5.5” pulley up to 400hp, or 10 years for a street motor. The MINI pulleys are 5.67” or 5.75” for a 2%.
ATI rebuilds the pulleys for $75 if no other parts are necessary.
What % SC pulley with your 2% ATI, and what belt size are you using?
Old Aug 28, 2020 | 02:02 PM
Derek86's Avatar
Derek86
Factory JCW pulley. I'll have to check on the belt size.
Old Aug 28, 2020 | 02:33 PM
mr.r50's Avatar
mr.r50
the site is very very unclear on the rebuild times on these things yet idk even how to inspect it to even see if it’s still good or not, only thing i can say is my motor still runs? 🤷🏻‍♂️
Andrew Riley
Jan 18, 2023 02:02 PM
elightbo
Jun 4, 2017 04:39 PM
mgoony
Oct 12, 2008 05:38 PM
agile_moments
Sep 28, 2005 09:56 PM
PressurizedMini
Jul 29, 2005 07:31 PM
